Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Tcase issue?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Tcase issue? (Read 1289 times)
Mudhawg
Talks waaay too much!
Rig Life
Tcase issue?
on:
April 03, 2009, 12:27:25 AM »
been noticing with my jeep lately it wont shift back into 2wd easily when coming from 4wd.. is there some certain trick? Jeep Newb
Logged
1984 Chevy 6" Lift 40" Boggers
JackstandJohnny
where Jeeps go to die
Re: Tcase issue?
Reply #1 on:
April 03, 2009, 08:21:52 AM »
what do u mean doug? the shifter won't physically move? or ur 4x4 light is still on? if its the latter (4x4 light) its probably a problem with your central axle disconnect.
might wanna hit up
www.naxja.org
too, seeing as ur always on the net
might as well start reading some useful info to fix ur everbreaking jeep
Logged
~ rescue green JKUR on 35s. typical rubicon build
superspud
Guest
Re: Tcase issue?
Reply #2 on:
April 03, 2009, 09:08:21 AM »
not to jack this thread (which i kinda am), but you expalin a little more about the 4x4 ligh staying on?
sometines mine stays on for a minute or so after wards, but i know it slip out of 4x4... figured it was just another buggered sensor.
Logged
JackstandJohnny
Re: Tcase issue?
Reply #3 on:
April 03, 2009, 09:15:03 AM »
if ur driving an earlier YJ or XJ the front axle has whats called a 'central axle disconnect' this is a b*tch. basically the passenger side axle shaft has two pieces, and the 'central axle disconnect' will slide a sleeve over the outer axle shaft when u put it in 4wd. this also activates the 4wd light. common 4wd failures happen when the CAD doesn't engage. tcase is in 4wd but axles not essentially.
my YJ does the same thing. light stays on for a while but i i KNOW its not in 4wd. personally i don't really care if it sticks with the axle connected, its when the 4wd light DOESN'T come on i'd be scared
Logged
Mudhawg
Rig Life
Re: Tcase issue?
Reply #4 on:
April 03, 2009, 12:08:17 PM »
well the light wont turn off and it takes forver for the front axle to disconect shifter moves no problem but the front diff wont disconect
Logged
JackstandJohnny
Re: Tcase issue?
Reply #5 on:
April 03, 2009, 01:12:25 PM »
u just diagnosed your own problem.
so answer. no ur tcase is just fine
ur central axle disconnect is finnicky. its fine to drive with it still connected. i do. at least ur 4wd will still work.
options: put in a posi loc cable, and u can manually connect/disconnect it. like 200 bucks or something.
or live with it..........
Logged
The Machinist
CJA Members
That CB Yapper
I’m with stupid!
Re: Tcase issue?
Reply #6 on:
April 03, 2009, 02:00:00 PM »
Get rid of the two piece and put in one solid shaft from a newer dana 30.
Logged
I just can’t resist a good mud hole! 🤦
JackstandJohnny
Re: Tcase issue?
Reply #7 on:
April 03, 2009, 02:31:49 PM »
to my knowledge u need to change the axle seal when doing this as well correct? i believe they are different......
Logged
rws
CJA Members
Stump Grinder
Re: Tcase issue?
Reply #8 on:
April 03, 2009, 03:34:47 PM »
Yes the axle seal on the two piece axle is different, the diameter of the solid shaft is much less.
Logged
cLAY
Re: Tcase issue?
Reply #9 on:
April 03, 2009, 04:53:13 PM »
Doug,
Which t-case do you have? Command trac(NP231) or Select-Trac(NP242). Usually the Limited's came with the Select-Trac system that has the Full Time 4wd position(basically AWD) and these models don't have a CAD axle.
Logged
Mudhawg
Rig Life
Re: Tcase issue?
Reply #10 on:
April 03, 2009, 04:56:46 PM »
ya its the selec track i believe ill have to check later
Logged
JackstandJohnny
Re: Tcase issue?
Reply #11 on:
April 03, 2009, 05:20:56 PM »
douggie, if its select trac (np 242) you'll have 5 selections, 2hi, 4hi, 4hi part time (like AWD) neutral and 4 low....
the command (np 231) just has 2hi 4hi neutral and 4low
the 231 will have the CAD axle.....
Logged
Mudhawg
Rig Life
Re: Tcase issue?
Reply #12 on:
April 03, 2009, 05:24:39 PM »
okay its the NP242
thanks Johnny
Logged
cLAY
Re: Tcase issue?
Reply #13 on:
April 03, 2009, 05:28:31 PM »
No CAD axle then. Front axle is permantly locked like the new Jeeps.
Is it sticking in 4wd or just slow for the light to go out? The light is activated by engine vacuum. A line runs from the engine all the way to the t-case and then back up to the engine compartment. Sometimes after you shift out of 4wd it take awhile for the vacuum to bleed off.
Logged
Mudhawg
Rig Life
Re: Tcase issue?
Reply #14 on:
April 03, 2009, 05:30:43 PM »
takes a while for light to go off and seems like it takes a bit for it to come outa 4wd as well
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Tcase issue?
