Author Topic: Storing Hardtop  (Read 2450 times)
Offline Whiskeymetal
Storing Hardtop
« on: April 06, 2009, 03:10:53 PM »
Hey everyone..
Spring/summer is lurking around the corner, any suggestions or good ideas for (properly) storing the hardtop for the summer?! I am kinda looking for a space saver as well.
I ran the thought of making a pulley system to tie it to the rafters of my garage, but I know something WILL go wrong with my luck.
-Cheers
'99 With 31's
Offline Evil-Jeep
Re: Storing Hardtop
« Reply #1 on: April 06, 2009, 03:29:12 PM »
I just built a wooden stand in the backyard to leave mine on bolt it down to it...... also made a great place to store bikes and lawnmowers
Offline fony3
Re: Storing Hardtop
« Reply #2 on: April 06, 2009, 04:59:39 PM »
You could also hang it from the roof of your garage....I am hoping to build one of those this spring!
P-Dubb
Re: Storing Hardtop
« Reply #3 on: April 06, 2009, 06:18:20 PM »
yeah, my step dad always hangs it from the rafters of the garage, he made a crazy contraption a while ago that stored hard and soft top in the roof.
Offline Gearhead
Re: Storing Hardtop
« Reply #4 on: April 06, 2009, 06:37:18 PM »
A couple of years ago I decided hard tops are for wimps and sold mine , eliminating the storage problem . Happy with the thought that it's much easier to store $500 .
I still have another jeep with a hard top ( my sweetie drives that one ) , in the summer , her hard top gets parked on a pallot in the backyard.
Re: Storing Hardtop
« Reply #5 on: April 06, 2009, 09:43:03 PM »
truer words have never been spoken....... i'm selling mine for a softy too
Offline thumper
  • Why question when you can assume.
Re: Storing Hardtop
« Reply #6 on: April 06, 2009, 10:05:37 PM »
     Four good hooks into the garage ceiling: $38.00          Two 1000 lb straps: $21.00     Some rope as a back-up: $ 6.00     Not having the damn thing on the ground to trip over all summer: Priceless
'03 Rubi, modded, with boggers
'05 'Vette
'07 Trailblazer SS, family & jeep hauler
'07 Savana, work
Re: Storing Hardtop
« Reply #7 on: April 06, 2009, 10:08:17 PM »
nice!!
Re: Storing Hardtop
« Reply #8 on: April 06, 2009, 10:11:14 PM »
as dumb as it sounds, do yo uhave a pic of your set up?   or anyone whos hangin it from the roof? i'd love to take  alook
Re: Storing Hardtop
« Reply #9 on: April 07, 2009, 08:27:13 AM »
I Agree.. I would like to do the same, so a pick of ones that have worked for a guideline would be greatly appreciated!
'99 With 31's
Offline Rookie
Re: Storing Hardtop
« Reply #10 on: April 07, 2009, 04:33:36 PM »
Here you go
http://wrangler.kicks-arse.net/HardtopHoist.htm
There's a couple of DIY projects on that site
Steve
TJ with some stuff
Offline fony3
Re: Storing Hardtop
« Reply #11 on: April 07, 2009, 05:55:09 PM »
This thread has a picture of a couple JK top storage ideas and at the bottom there are tons are related threads of with more pictures....
http://www.jeepforum.com/forum/showthread.php?p=6844007
I was planning something of a mix between the JK ideas and this website
http://www.stu-offroad.com/body/hardtopstor/hardtopstorage.htm
I have heard that the hard top will spread if you hook the outsides like that.
I am thinking of using hooks and straps and a wood platform/frame the hard top bolts to...
Doing more looking around I found this idea, would it be hard on the top sitting like this? Definitely a space saver.
http://www.jeepforum.com/forum/showthread.php?t=395770
« Last Edit: April 07, 2009, 06:20:14 PM by fony3 »
Offline Lugnut
  • At least its still a Jeep...
Re: Storing Hardtop
« Reply #12 on: April 07, 2009, 06:28:30 PM »
I hang mine from the garage roof every summer as well.
I use;
4) eyehooks (5/16") and 2 sets of motorcycle tiedowns. (None ratcheting tiedowns, get a good set of "Ancra" brand, they will last you forever)
- Mount eyehooks into ceiling studs slightly wider than width of top (Drill pilot holes first)
- Hook rear tiedowns to ceiling eyehooks and rear bottom lip of Jeep top
- Hook front tiedowns to ceiling eyehooks and ends together under front section of Jeep top
- Suck her up to the ceiling
- use small amounts (4") at each tiedown, I find front / back until half way up, then switch sides and repeat
For the rear hooks at the bottom rear lip of the top, I open these up so I can use a 1" x 6" long piece of wooden dowelling to spread the weight across the 6"s.  For the front, I just throw a little foam between the top and the straps once I have her at the ceiling.
When connecting the front straps together , remember to go OVER the rollcage, else she will seem REALLY heavy to lift.
03 Black Rubi, 4"lift, 33s, Warn 9.5ti - SOLD
07 Jeep Grand Cherokee SRT8 .. 13.8 secs @100.4 mph
Offline TJ54
Re: Storing Hardtop
« Reply #13 on: April 07, 2009, 09:07:22 PM »
Did you learn that the hard way ?     ;D
Offline thumper
Re: Storing Hardtop
« Reply #14 on: April 07, 2009, 09:17:31 PM »
When connecting the front straps together , remember to go OVER the rollcage, else she will seem REALLY heavy to lift.    [/quote]          Oh man! I did that a few years ago. wrecked a strap because I have a habit of forcing things  ::)     I don't have a photo of my set-up. I just back up under the hooks, loosed the top and lift with ratchet straps. I protect the contact points with bits of wooden corner moulding. I string a rope under it just in case
'05 'Vette
'07 Savana, work
