Author Topic: TF 727 install  (Read 923 times)
Offline Eagle Jeeper
TF 727 install
« on: April 08, 2009, 12:12:03 PM »
I just finished installing my auto tranny and I am just wondering what the correct procedure for filling with fluid is because I know you shouldn't check the fluid unless running hot in neutral.
Re: TF 727 install
« Reply #1 on: April 08, 2009, 10:05:42 PM »
chryslers all seem to be running in neutral hot. once at that point go for a drive and shift throug hall gears and then re-check.
Re: TF 727 install
« Reply #2 on: April 15, 2009, 05:34:21 PM »
OK but before that when the tranny is dry how much fluid do you put in to start.  Then do you start the motor and let it warm up. Then check and add accordingly how much fluid does an auto tranny usually take.  Sorry I'm new to the auto world.
Offline 2grand4u
Re: TF 727 install
« Reply #3 on: April 15, 2009, 05:41:06 PM »
when i put my 42re in my grand it took 8 things of atf i just pored it in then checked without running, made sure it was close then started and added tell it was perfect.
i'm not sure if it helps but that is what i know
Re: TF 727 install
« Reply #4 on: April 15, 2009, 06:04:59 PM »
Makes sense if you fill it to full the fluid should go down because you still need to fill up the converter and cooler.
