Author Topic: Dana 35 Spider gear replacement help...  (Read 1493 times)
Jeepster
« on: April 16, 2009, 12:52:24 PM »
Just discovered that I have some broken teeth (on spider gears) on my rear Dana 35 (1994 YJ).
How hard are they to replace ?
I have never done it, heck I have never even looked at the inside of a diff until 2 days ago LOL
Think I could replace them myself ?
Can I put used ones in ? (I was layed off a few weeks ago so I have limited funds, if any).
Does anyone have any used ones ?
Any help would be awesome. I really want to get it on the road asap since the weather is finally starting to act nice.
Offline LEMON-AID JAY
  • Bad a$$ zj owner
Re: Dana 35 Spider gear replacement help...
« Reply #1 on: April 16, 2009, 01:20:20 PM »
give me a call at the shop I think I have some here and I can tell you how to replace them 287-3350 :) ask for jay
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Jeepster
« Reply #2 on: April 16, 2009, 06:04:51 PM »
Thanks a TON Jay for the gears...
I really appreciate the help, and your generosity.
 Now I just need to get them in ;D
« Reply #3 on: April 17, 2009, 05:26:20 PM »
Now is a REALLY good time to install a lunchbox locker.....
Jeepster
« Reply #4 on: April 17, 2009, 05:49:16 PM »
Would love to if I had the cash...
For now this is going to have to do I am afraid.
Jeepster
« Reply #5 on: April 22, 2009, 10:05:58 AM »
Ok so far I have have...
1. Removed center pin
2. Removed tires and drums
3. Slid axle shafts in and removed C clips.
4. Slid axle shafts out.
So how do you get the spider gears out now ?
If I rotate the pinion, the spider gears do not turn ?
Offline jandh
« Reply #6 on: April 22, 2009, 10:16:59 AM »
If I remember correctly on the C-clip dana there are little black clips locked in place around the outisde of the carrier that need to be removed to get the spider gears out - but maybe let a Dana Guru confirm that - don't want you to do more work then you have too
1991 YJ
Jeepster
« Reply #7 on: April 22, 2009, 11:10:47 AM »
I cannot get them to turn at all...
The smaller of the gears have moved a bit but none of them will turn.
Can I remove the carrier to have better access to them ?
Jeepster
« Reply #8 on: April 22, 2009, 11:44:31 AM »
Well I got them out...
Only thing is the spider gears that Jay gave me are not the right ones :(
I am positive that it was the exact same D35 that he had at his shop tht they came out of.
Any ideas ?
Jeepster
« Reply #9 on: April 22, 2009, 11:55:57 AM »
Well it looks like I have Posi..
Anyone have any spider gears out of a D35 C clip with Posi ?
« Reply #10 on: April 22, 2009, 12:04:14 PM »
I think I do.
There are at least 3-4 different sets of spiders for d35's. Bring your old ones over, we can try to match them up. I've repaired a few traclocs, so I should have  set around somewhere.
Jeepster
« Reply #11 on: April 22, 2009, 02:18:05 PM »
Thanks Bnine...
Sent you a PM.
