Author Topic: Over The Top Steering install  (Read 1453 times)
Offline raf2379
« on: April 23, 2009, 06:47:26 PM »
So I was looking for an upgrade of my steering, i looked at the Currie enterprises system, but its just a beefed up Haltenberger Steering linkage just like stock $399 US. I was also thinking about the teraflex high steer knuckles, but they are $400 each, so despite all the bad customer service rants I've heard about Rocky Road Outfitters, I have ordered the OTT steering system from them, and received the parts within 3 weeks $549 US http://www.rocky-road.com/xjott.html as i began installing the system I've found some isues with the system, nothing major just small stuff in my opinion, nothing that a grinder wont fix to make the brackets fit better. The other thing I've found was that the swaybar mounts were interfering with the tie-rod when steering at full lock left or right, explained more with the pictures below. The only reason it was interfering was because i wanted to use my quick disconects, as oppose to the disconects that are provided by RRO which fit good and do not interfere. So I had to modify it by a little grinding and welding to make it work for me. Other than that I think it is a descent system for the money, and you get the over the top steering setup which is the main reason I went for this kit. The angles of the Track bar and draglink are spot on parallel. anyways onto the pictures.
Stock setup, quite steep angles
Bare knuckle to make installation easier
Grinding of the knuckle as per RRO instructions require the knuckle to be flat for the new high-steer knuckle to sit on there properly
Fitting the new knuckle
Depending on what style knuckles you have on your dana 30, you may have a little gap, but its ok because there is a shim included in the kit for the new knuckle to fit properly.
drilling and tapping required for the new knucles to bolt on
the knuckles bolt in 5 places to make it as tight as possible. two bolts on the back, and three on the top
instaling the knuckles was easy and it took me maybe 2 hour to remove the brakes, axles, drill tap and bolt on both sides. Now the time consuming part was the brackets, lots of care had to be taken to make sure the holes were drilled in the proper locations and that the bracket fit perfectly, there was grinding and hammering involved. one thing ive found was that the pasanger bracket was very dificult to make it fit properly and one part of the bracket that sits on the axle tube was preventing it from sliding on all the way as seen in the pictures below.
Grinding away a pice of the stock bracket as per RRO instructions
this is the part of the bracket that gave me some trouble and did not allow the bracket to slide on all the way, but some hamering and grinding i made it fit.
as you can see in this image what i mean by it not sliding on all the way even if you try to hamer it on. it was due to the part of the bracket in the above two pictures not welded in the right spot in my opinion, it was off by a 1/4".
the bracket sits verry close to the coil spring. no rubing, but close.
this is where the swaybar connects interfear with the tie-rod when steering wheel at full lock, so i had to cut the bolt off and weld on my own piece for the swaybar to connect a little higher.
here are rest of the pictures of everything instaled and new swaybar disconects welded on and modified RE second Gen disconects.
If anyone has any questions or maybe some sugestions to the swaybar modification, please feel free to ask and comment.
Besides the few modifications, the kit was fairly easy to install and it seems to be performing well so far. not bad for $549 US
« Last Edit: April 23, 2009, 06:58:53 PM by raf2379 »
Offline jandh
Re: Over The Top Steering install
« Reply #1 on: April 23, 2009, 09:32:49 PM »
Very nice!   That sure took the angle off of everything under there
How many hours in total did the upgrade take?
1991 YJ
« Reply #2 on: April 23, 2009, 09:58:04 PM »
Honestly, looking at all the bolts, angles and braces.....doesn't really give me a warm fuzzy feeling. Maybe it looks better in person.....
« Reply #3 on: April 23, 2009, 10:32:01 PM »
very nice .. do you know if they make a kit for the TJ
Offline rws
  • Stump Grinder
« Reply #4 on: April 24, 2009, 09:17:28 AM »
I have been looking at the same kit.
On your orginal steering you had a a RE1600 trackbar.  Did the RR trackbar fit tightly in the frame bracket hole?
Offline raf2379
« Reply #5 on: April 24, 2009, 05:33:06 PM »
i would say it took me 12hours, due to the fact i did not want to use the RRO swaybar disconects and had to fabricate my own using the RE 2nd Gen disconects.
it does look like a lot of bols, only time will tell to see how this kit holds up. once i'm finished my New D30 i am planing on welding the brackets on permanently.
I believe they do make them for the TJ, its the same system prety much.
yeah i had the RE1600 track bar, and i had to goto pick N pull to go grab another stock trackbar bracket because the one for the RE trackbar had to be drilled out for the bigger bolt and the RRO trackbar uses stock tierod end.
Offline calltrex
« Reply #6 on: April 24, 2009, 09:54:59 PM »
looks beefy
nice
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
