Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Bleeding the brakes
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Bleeding the brakes (Read 670 times)
Eagle Jeeper
Budget Lift
Bleeding the brakes
on:
April 24, 2009, 07:44:22 PM »
I picked up and installed a hydroboost system from PNP from a 79 one tonne Chevy into my 94 YJ with Chevy axles. The problem is I can't seem to get much pressure on the lines when bleeding. I think the MC might be pooched but I don't know enough about them to make that assumption. I tried bleeding the brakes starting at the RR wheel. The first push on the peddle gives not bad results but it get progressively worse to where if you hold your finger over the end of the line there is almost no pressure at all. The other thing is that the peddle doesn't seem to return very quickly at all. Any help from the mechanics out there would be helpful.
THanks
Murray
Logged
94 YJj7, AMC360,T176,Dana300(twin stick, Dana 44 4:56, 14 bolt FF welded 4:56, 2 1/2" susp SOA, 38/12.5/15 TSL's, warn 8274, Custom dash
hps4evr
Administrator
Talks waaay too much!
Re: Bleeding the brakes
Reply #1 on:
April 25, 2009, 05:41:13 PM »
whats the general condition of all the brakes including calipers, rotors, pads, drums, wheel cyls?
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Bleeding the brakes
