Author Topic: Electric brake controller  (Read 758 times)
Offline McClare
« on: April 29, 2009, 05:40:43 PM »
Vehicle is 2001 Jeep Cherokee sport 4x4 4.0L Auto
I'm looking to wire in a brake controller. 4 wires need to go to the controller: Positive, Negative (ground), Blue wire that goes to the 7 pin connector at the rear, and a wire that comes off the 'cold side' of the brake switch. I can't find my haynes manual to look at a wiring diagram but does anyone know what wire this is off hand? I looked at the brake switch and it has like 8 wires going to it. I figured it would be 2 wires, one with power and one without. Any help is appreciated.
1992 MJ, 3" skyjacker, 31" BFG MT, Rollbar
Offline Crunch
Re: Electric brake controller
« Reply #1 on: April 29, 2009, 07:57:41 PM »
take a test light and depress the brake pedal-tap into the wire that lights up-this will be your signal power to close your switch
and send power through your brake contoller through the blue wire to the trailer plug-any questions  pm me I'll walk tou through it
Offline S-FLY
  • '94 XJ
« Reply #2 on: May 01, 2009, 09:21:22 AM »
The White/Tan wire.  ;)
ve1sly
