Author Topic: weird tranny fluid color...  (Read 3130 times)
superspud
« on: May 01, 2009, 04:12:07 PM »
ok so i checked my tranny fluid today since i have been grinding into 2nd gear and instead of a nice pink redline color its a weird milky white color......possibly water? i did go through one water crossing a while ago....not sure if was that deep though.
thx for any help.
Re: weird tranny fluid color...
« Reply #1 on: May 01, 2009, 04:29:01 PM »
RED ... ATF... it would be Red if if was normal... Pink if you have a bit of water in it ...
White... How deep  was that hole and how long you stayed in it?... I would get my tranny flushed if I was you and get new ATF right away.
I have neber seen white ATF before... I might be wrong
« Reply #2 on: May 01, 2009, 04:29:32 PM »
Sounds like water for sure.  If you have not checked your diffs and I do that ASAP.  Any time you go through deep water or mud and should check and/or changes your fluids after
Throw in a good synthetic and your tranny with thank you.  I am currently using Redline and it made my tranny work smoother and quieter
superspud
« Reply #3 on: May 01, 2009, 04:47:11 PM »
how should i flush my tranny? what fluid do i use in my diffs?
it was just a extra deep street puddle, and i dident stay in it. water splashed over my windsheild....mabey halfway up the tires.
« Reply #4 on: May 01, 2009, 04:58:57 PM »
Has the tranny been flushed before, if its a high mileage vehicle flushing the tranny for the first time can cause more harm than good.  If so, drain the tranny fluid and change the filter, refill with new fluid.  Drive it for a week and then drain the fluid again and refill.  The stuff I have in my diffs right now is Amsoil Severe Gear 75W-90, the Redline tranny fluid that was mentioned is good, its going in after the 101.
superspud
« Reply #5 on: May 01, 2009, 05:05:22 PM »
ok seems reasonable. so two last questions.....where is the transmission filter. and what kind for fluid can i put in there for cheap as a flush fluid?
and red line is good for the diffs? i know my tranny like me after i put it in.
« Reply #6 on: May 01, 2009, 05:20:35 PM »
The filter is bolted to the tranny , inside the pan so you have to drop that first.  The way I did it was only take to bolts out of one side so the fluid spills out the side into a collection pan, not falling all over the place.  Unbolt filter and replace, clean out pan and magnet.  Clean the mating surface with brake cleaner and a wire brush if needed.  Apply new gasket to surface and coat with a thin film of RTV, bolt pan up again and let the RTV set up for a bit (beer time).  Refill fluid using a funnel, the fill tube will be near the firewall under the hood.  ATF+4 or +3 depending on what your Jeep needs is cheap enough that you can use it the first time until you refill with Redline.
« Reply #7 on: May 01, 2009, 05:53:06 PM »
is this tranny a manual or auto? if auto then yes, drop pan, change filter, re-install pan. fill with atf +4. running in neutral.
if manual. drain fluid. fill fluid till it comes out of fill hole. done.
as well, if its manual let the fluid sit for a while. if you just drove home and checked the fluid it may look white as its full of bubbles from being thrown around in the trans.
superspud
« Reply #8 on: May 01, 2009, 09:08:16 PM »
its a manual. ax5
Offline Mudpig97
« Reply #9 on: May 01, 2009, 10:00:00 PM »
Better check the t/case as well.
85 CJ7, toy axles and 35's, miller locker in rear.
superspud
« Reply #10 on: May 01, 2009, 10:49:55 PM »
thanks for all you help guys. what a great forum.
« Reply #11 on: May 02, 2009, 02:45:19 AM »
ax5! oh. well then you better be ready to fix those syncros soon. you still have 5th gear?
superspud
« Reply #12 on: May 02, 2009, 07:59:52 AM »
ya i have 5th, but down shifting into second grinds a bit.
superspud
« Reply #13 on: May 02, 2009, 02:33:30 PM »
update. i change it out with some super cheap fluid and now its just a bit notchey to down shift into second, havent tried 5th yet.  im sure the tranny will love me alot more a about three days when i replace it all with redline.  is redline good for the t case as well as diffs?
« Reply #14 on: May 04, 2009, 07:22:52 AM »
I use synthetics in my tranny (redline)and t-case (royal purple) as I change them about once maybe twice per year.  In my diffs I usually just use standard dino oil, 80w-90 as that get changed a lot more because of mud and water.  When I was actually offroading a lot it was not uncommom for me to change my diffs 5-6 times in a summer.
