Author Topic: Oh crap, did I just bend my driveshaft?  (Read 1274 times)
Offline Duncan71
« on: May 12, 2009, 02:34:00 PM »
I just put my driveshaft in a vice to pound on the U joint. Took quite a beating to get er out, but now Ive noticed I dented in a bit where the DS rested on the vice. Do we figure ive just dented it a bit(which should still be ok) or have I bent the whole damn thing?
FullMetalJeep
Re: Oh crap, did I just bend my driveshaft?
« Reply #1 on: May 12, 2009, 03:12:52 PM »
a torch is your friend.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #2 on: May 12, 2009, 05:24:54 PM »
Quote
I bent my ears on an axleshaft trying to get the joint out... expensive lesson.  I now have a Princess Auto Ujoint tool.
I found the vice/socket hammer method was definitely pretty brutal.  I got the Princess Auto ujoint tool, only to later buy the ball joint tool.  Much easier.  I did however try to power out a seized ujoint only to bend the ear since I used an impact with the ujoint tool.
Only way to know for sure is to put it back on and go for a drive.
98 TJ 4" lift + goodies
Offline GiS
« Reply #3 on: May 13, 2009, 07:15:20 AM »
Run it, your likely just going to hit it and dent it again on some stumps or the two rocks we have in Alberta,
Or if its fromt a 4.0L TJ, I'll buy it at salvage pricing :)
Offline Layback209
« Reply #4 on: May 13, 2009, 06:29:51 PM »
Im a fan of the $10 c-clamp and big socket method.  Push them both out as far as you can get the caps, the finish it of with a hamer using a piece of WOOD under you drive shaft.
Its not as fast and easy as the official tool, but works just fine.
Offline newfie
  • newbie and loven it
« Reply #5 on: May 13, 2009, 10:22:47 PM »
go to PA and picl up the ball joint and u joint tool
 its sooooooooooooo worth the money !!!!!!
my  2 cents
newfies are everywhere
