Author Topic: Fuel Problem? not sure.  (Read 780 times)
phogan
« on: May 16, 2009, 09:49:38 AM »
hi there.  having a problem with my fuel, or with the gauge.  not sure.  but, when i get to about 1/4 tank of gas, sometimes i lose all power in the pedal but the jeep does not turn off, just doesnt move.
fuel filter?
thanks alot.
Re: Fuel Problem? not sure.
« Reply #1 on: May 18, 2009, 01:05:07 PM »
what you're sayin is it will idle but it wont accel or rev up when its getting low on fuel? my fuel gauge stops at 1/4 tank. maybe you're actually running out of fuel. or, the pick-up filter is plugged up are starved cause its not positioned properly. try a fuel filter but id drop the tank to be sure.
phogan
« Reply #2 on: May 20, 2009, 12:37:28 PM »
Quote
thanks for the advice, unf i dont have the facilities, tools, money or brains to take my tank off.  i got it down to about an eighth of a tank last night before it started to slug out.  i am going to try running a cleaner through it, and see if that helps, and aside from that, i am stuck driving it till it becomes more problematic.  thanks alot.
