Author Topic: Brink's '09 Mods  (Read 26831 times)
Offline Brink
Re: Brink's '09 Mods
« Reply #60 on: March 21, 2010, 10:35:42 PM »
Motor is done and back in where it belongs.  It measured out with the plastigauge perfectly within factory spec during assembly.  Bolted back into the engine bay without a hitch...
Offline Brink
« Reply #61 on: March 21, 2010, 10:36:38 PM »
Finished the exhaust.  All 3.5" and used a Magnaflow round muffler.  Pretty much straight through, may add a resonator after the muffler or on of Dynatech's tips with the silencer in it depending on decibel levels when the engine fires...
One seriously tight fit in places...
Offline Brink
« Reply #62 on: March 21, 2010, 10:37:20 PM »
Tore out all the wiring that was done before.  It was all just crimps and maybe a little quick and questionable.  Now it is all soldered conections and very dependable.  Built a new fuse/relay center also.  Completely waterproof....
Offline Zombie
  • Jeff the Zombie Jeep
« Reply #63 on: March 21, 2010, 11:17:06 PM »
and you made such a nice spot to pack a lunch too! ;)
very creative way to  get it done, nice and simple.
Offline mike s
  • Good times!
« Reply #64 on: March 21, 2010, 11:42:21 PM »
Nice clean install, and where you can get to as well, nice. What colour did you use for the block and valve covers? Looks great!!!
oldEnuff2NObetter
but still can't help myself
Offline Brink
« Reply #65 on: March 22, 2010, 12:15:40 AM »
Thanks guys.
Block/valve covers are the same Orange Crush Pearl Endura that the jeep was shot in.  Heads are just regular Alum high heat engine paint.
Offline Brink
« Reply #66 on: April 09, 2010, 09:57:40 PM »
Needed to build a new mount for the alternator.  Changing from the huge but low power Caddy unit to more modern 1 wire Chevy high output model.  The Chevy mounts totally the oposite way on the bottom....
Offline Brink
« Reply #67 on: April 09, 2010, 10:02:21 PM »
Then built a new bracket to lower the power steering pump so the reservoir could gravity feed better....
Offline Waytec
  • not all there
« Reply #68 on: April 09, 2010, 10:06:35 PM »
Looking good  :)
The obstacle is the path.
Offline Brink
« Reply #69 on: April 09, 2010, 10:06:43 PM »
Great ways to test out the new Longevity Plasma.  First cut was freehand on 5/8 plate...
Engine is almost wrapped now...
Offline Waytec
  • not all there
« Reply #70 on: April 09, 2010, 11:08:38 PM »
so no more sitting the driver seat making vroom, vroom, vroom noses to yourself.
Offline Brink
« Reply #71 on: June 28, 2010, 11:57:42 PM »
Sorry for the lack of updates.  Been busting on it trying to get it done.
Suddenly it all became worth while....
Offline Brink
« Reply #72 on: June 29, 2010, 12:01:16 AM »
Offline raf2379
« Reply #73 on: June 29, 2010, 07:36:26 PM »
nice work looks like the suspention is performing great, nice articulation must be loads of fun to drive this thing.
Offline rosko
« Reply #74 on: July 16, 2010, 04:36:05 PM »
That thing is scary lookin' .... in a good way.  :D
Teraflex Tummy Tuck
