Author Topic: amc 360 missing at high speed.  (Read 878 times)
Offline Eagle Jeeper
« on: May 21, 2009, 10:59:08 PM »
Just like it says when I get up to speed its like the motor just bucks really bad. the combination is an amc 360/tf727/dana300.  I just put it in the jeep but it came out of my old jeep and ran fine.  I just did the TFI ignition upgrade and seems to idle not bad.  WHen you punch it, it catches right away its just seems like when the tranny is in high gear is when the problem is.  Any ideas would be great.
THanks
Offline stroker sahara
Re: amc 360 missing at high speed.
« Reply #1 on: May 21, 2009, 11:04:58 PM »
New plugs and wires, heavy on the wires.
« Reply #2 on: May 21, 2009, 11:09:58 PM »
I did that too brand new plugs and new 8mm napa wires
« Reply #3 on: May 22, 2009, 06:45:18 AM »
Just a thought but could an improperly adjusted kickdown cable have this effect, or also the carb
Offline rangerdanger
« Reply #4 on: May 22, 2009, 07:36:28 PM »
Fuel pump? might not be able to deliver enough fuel at speed
Lethbridge Coulee Kruzer
« Reply #5 on: May 24, 2009, 04:17:31 PM »
its the stock motor and pump maybe the filter is plugged.
