Author Topic: power steering box  (Read 2663 times)
Offline nickcoleman9
power steering box
« on: May 24, 2009, 07:23:00 PM »
Hey guys so i was out on Saturday and i hit the box on my 95 yj is it worth rebuilding?
or should i go to pnp and just grab one? also if i go that route what fits? would a cherokee or something bolt in, or is there an easy upgrade?
i guess i should build a skid for it..... thanks NICK
« Last Edit: May 31, 2009, 10:34:17 AM by nickcoleman9 »
Offline fug
  • Airdrie Pick n Pull
Re: power steering pump?
« Reply #1 on: May 24, 2009, 08:10:13 PM »
Pump?  or box?  I'm thinking hitting the pump would be somewhat difficult.
Fug
TJ Rubicon
Offline Fredduck
  • RIDE ON
« Reply #2 on: May 24, 2009, 09:44:03 PM »
I was thinking the same thing
« Reply #3 on: May 25, 2009, 08:15:20 AM »
sorry yeah the box my bad
Offline S-FLY
  • '94 XJ
« Reply #4 on: May 25, 2009, 09:25:52 AM »
I'd just grab one from PnP.  I think I paid $29 for my pump at PnP, and I'm pretty sure they're the same as the YJ.  Sprockett will know for sure, I just gave him an XJ pump to try on his YJ.
« Last Edit: May 25, 2009, 09:36:22 AM by S-FLY »
ve1sly
Offline S-FLY
  • '94 XJ
« Reply #5 on: May 26, 2009, 04:44:31 PM »
Apparently the power steering pump is different.
ve1sly
Offline LifesGrand
« Reply #6 on: May 26, 2009, 05:03:39 PM »
I don't have the answer, but it sounds like a durango box will work as an upgrade? May want to search more on that... The second link is more for adjustments if you need for reference once you find what your looking for.
http://www.jeepforum.com/forum/showthread.php?t=518702&highlight=power+steering+box
http://www.jeepforum.com/forum/showthread.php?t=498155
Cheers..
95 ZJ v8 Ltd.
Offline Tanner
« Reply #7 on: May 28, 2009, 11:45:06 AM »
What is PNP????
I also need a box but for a 77 CJ7. Has anyone shoe horned a box from another model into a CJ? The rebuilt box for that jeep is $700+ so if I can find a cheaper option that works I would be all over it.
Offline Pookapotamus
« Reply #8 on: May 28, 2009, 12:28:39 PM »
pnp = pick and pull
Offline Grease Nipple
« Reply #9 on: May 30, 2009, 09:05:04 AM »
I have a steering box from a 95 grand 5.2.
I pulled one from PNP last week, they charged me $40, turns out the problem was not with my steering box. So I have a good steering box sitting in the garage.
I'd take a case of beer for it.
« Last Edit: May 31, 2009, 08:49:40 PM by ibyers »
« Reply #10 on: May 30, 2009, 11:08:20 PM »
anyone know if this will fit??
Re: power steering box
« Reply #11 on: June 08, 2009, 07:52:27 PM »
What is PNP????
CJ boxes are dime a dozen. Get a wrecker to cross it, but just about any saginaw box from a bout 10 million bazillion ford and chev trucks over the last 30 years will bolt in.
Most you should pay for a remain is about 350 plus core. Give or take.
« Reply #12 on: June 08, 2009, 07:53:09 PM »
If its a 3 bolt saginaw, it should work nick. Just measure your bolt pattern and double check when you look at it.
