Author Topic: Engine fan blew up  (Read 1024 times)
Offline Sprockett
Engine fan blew up
« on: May 24, 2009, 08:32:56 PM »
So the fan darn near totally separated from the shaft today. Took out my 3 month old radiator and a chunk from the power steering pulley. I had to yank it and limp home with zero coolant. I assume it had something to do with the headlight high water I was in earlier in the day :( Could pushing water like this cause this kind of failure or is coincidence?
Question is, what do I do now for the fan?
Brand new? Junk yard? Electric? Is it worth going junk yard when the clutch is a wear item? Is electric reasonable if I go plowing through water again?
Did I mention mud/water/bogging sucks?
Offline Fredduck
  • RIDE ON
Re: Engine fan blew up
« Reply #1 on: May 24, 2009, 09:00:16 PM »
If your going diving  ;D again I suggest an electric.
Call partsource I got a wicked deal on a 16 inch Hatdon elec. fan
Dragonmaster
« Reply #2 on: May 24, 2009, 09:04:27 PM »
As long as you install a shut off switch, electric is fine for water.
Offline Sprockett
« Reply #3 on: May 24, 2009, 09:23:50 PM »
Thanks,
:D
So pushing water like that could have been the death of my clutch/fan? Did you wire your electric with a temp sens? What's the CFM on that fan?
Ryan
Offline Fredduck
  • RIDE ON
« Reply #4 on: May 24, 2009, 09:43:05 PM »
Pushing water with the fan certainly won't increase it's life span.
Not sure on the CFM but it should be on their website.
We did put the fan on a temp switch.
 We used it as a puller not a pusher, way more efficient.
You can wire in an override switch to shut it off when you go swimming in the deep end as well.
Offline .:.Dingman.:.
« Reply #5 on: May 25, 2009, 11:54:12 PM »
care to say how much?
