Author Topic: release bearing repair time?  (Read 836 times)
Corey
« on: May 26, 2009, 11:40:33 AM »
Release beering repair time?
Re: release bearing repair time?
« Reply #1 on: May 26, 2009, 11:52:49 AM »
al least 12 beers
« Reply #2 on: May 26, 2009, 11:54:25 AM »
if you go in there to change it.. might as well change the clutch...
shop should charge you 4-5 hours.... I beleive
« Reply #3 on: May 26, 2009, 12:09:18 PM »
Don't forget about flywheel machining if required.
Corey
« Reply #4 on: May 26, 2009, 02:34:16 PM »
Clutch is 3 months old! Got the jeep berried up over the bottom of the doors and the muddy water just killed the beering! And shop time is 3.1 hrs
« Reply #5 on: May 26, 2009, 04:01:32 PM »
ok .. if you knew the time why did you ask? just wnat to make sure you didn't get screwed?....
I think there is no way around and you have to remove the tranny and the t-case to get to the rls bearing... I don't know any other way.. but I'm not a mechanic.
Mud is evil ..you see if you like mud and do lots of it... This sport will start being expensive. The Mud around Mclean is the worst. It's so fine that it gets everywhere.
Mud is evil... and boring
Corey
« Reply #6 on: May 27, 2009, 08:39:55 AM »
So true! Trail rides from now on! Really need an adjustable track bar front tires are taking a beating! Been 3 months and brand new 33's half warn!
