Author Topic: All Gages on Dash Died  (Read 1178 times)
Jeepgirl
« on: May 26, 2009, 09:33:20 PM »
I have a 1992 Jeep Yj and one day all the gages on the dash died. The fuel gage oil pressure gage and every other one. all the lights still work. Checked all the fuses and other connections does any one have any idea what else to check? its a complete mystery.
Offline 01sahara
Re: All Gages on Dash Died
« Reply #1 on: May 26, 2009, 09:45:23 PM »
Is there a ground conection to the dash frame. I had an s10 years ago the had guages that died on  and off turned out to be a loose ground dash frame to the firewall.
Offline Gearhead
« Reply #2 on: May 26, 2009, 10:07:54 PM »
On the fire wall , under the hood , in the vicinity of the map sensor , there's a gray connector . I can remember how many pins or which pin is what  there are at least eight wires , maybe more , wiggle that connector or look for corrosion . This is likely a bad connection. This connector has many of the wires for the guages , oil pressure , voltmeter , tempurature.
AB-Tuner
« Reply #3 on: May 29, 2009, 03:32:30 PM »
I have the same problem. I have a cluster of wires running under my dash, where my CD player ties in (Which I can't get working!!) I tucked the cluster back up into the dash one day and all my gauges began working again...
Offline Gearhead
« Reply #4 on: May 29, 2009, 10:16:48 PM »
Ah yes , home handi work / stereo install aftermath.
Offline barmanjay
« Reply #5 on: May 31, 2009, 08:48:46 PM »
crazy thing
mine just stopped working this afternoon too.
parked for dinner, hopped out, fired it up ad nothing. no speedo, tach or odo too.
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline barmanjay
« Reply #6 on: June 01, 2009, 03:12:33 PM »
I found my prob, it was a fuse marked 'lights'
go figure?
you guys should check all your fuses again.
Jason Kim
Realtor
889-4747
www.jaykim.ca
AB-Tuner
« Reply #7 on: June 04, 2009, 07:18:06 PM »
1st thing I did was check all my fuses and they were all good, mine turned out to be a bad wire somewhere under the dash coming from my accessory wire. I ended up splicing into it and tying it into my CD player (Which now works!) and my gauges now all work fine as well! Apart from my oil pressure gauge, which always reads 6...
Offline mike s
  • Good times!
« Reply #8 on: June 07, 2009, 11:59:24 PM »
Just finished putting in aftearket guages in my YJ. Have old cluster if you want to plug it in and see if it fixes everything. There are two power feeds and two grounds for the cluster so it's weird to have all of them quit. PM me if you need a hand.
oldEnuff2NObetter
but still can't help myself
