Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Stiff steering
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Stiff steering (Read 758 times)
LilRed36
Guest
Stiff steering
on:
May 27, 2009, 08:50:30 AM »
91 xj only in the morning or when it's been sitting for awhile the steering is stiff. Fluid is full no aparent leaks, any ideas.
Logged
Pookapotamus
Talks waaay too much!
Re: Stiff steering
Reply #1 on:
May 27, 2009, 11:22:45 AM »
old fluid?
Logged
LilRed36
Guest
Re: Stiff steering
Reply #2 on:
May 27, 2009, 12:50:41 PM »
Nope, drained it and replaced it all thought maybe there was water in it, did not work
Logged
Evil-Jeep
UberWheeler
Re: Stiff steering
Reply #3 on:
May 27, 2009, 01:11:04 PM »
three posibilities I can see. I would say that it is clearly a"being cold" issue as it appears to work fine once it runs for a bit or warms up.
My first instinct would have been fluid either too heavy or old, it sounds like you have ruled that out.
My second would be a pinched or bent line that is slowing the flow of the fluid.
Third would be a bad or failing pump.
I can't see any of the steering components causing stiff steering, and then loosen up as it warms up.
Logged
Pookapotamus
Re: Stiff steering
Reply #4 on:
May 27, 2009, 01:13:15 PM »
i agree with evil
Logged
LilRed36
Guest
Re: Stiff steering
Reply #5 on:
May 27, 2009, 03:19:43 PM »
I thought of the bent or kinked lines but nothing seems out of sort, unless its cavitating on the inside which is a possibility, or as you mentioned a diying pump. Add that to my list of upgrades, anyway thanks for the input guys I appreciate it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Stiff steering
