Author Topic: esp sensors in a jk  (Read 683 times)
Offline JK2008blckblck
esp sensors in a jk
« on: May 27, 2009, 11:04:25 PM »
anyone have an idea how to turn off the esp sensors in a jk? with the lift and tires in its all fucked up.
2008 jk 2 door
4 inch rough country
37x13.30 ss m-16
procomp rockcrawlers
rcx dual steering stabilizer
1 1/4" rcx body lift
rcx sway bar disco's
bushwacker flares
river raider snorkel
smittybilt front bumer and xrc 8000 winch
PIAA's all over
Offline AV.NINE
Re: esp sensors in a jk
« Reply #1 on: May 28, 2009, 01:06:58 AM »
First there is no way to completely disable them. 2nd make sure your steering wheel is 100% straight if its out even slightly it really messes with esp. 3rd, there is a TSB that allows ESP to be permanently turned off (but not truley off, just so you don't have to hit the button all the time), something like turn your wheel straight, hold esp for 3 secs, then half turn left hold esp then half turn right hold esp. But that's only as good as hitting the button and wont totally cut it off.
...I feel your pain.
« Reply #2 on: May 29, 2009, 11:29:30 AM »
There is a TSB out specifically to adress this issue. You need to go to the stealership, get your Jeep flashed, and then you can do the magical voodoo dance that will disable the ESP...or at least partially.
