Author Topic: Father's Day Open Run - June 21  (Read 18993 times)
fuzzylizard
Re: Father's Day Open Run - June 21
« Reply #45 on: June 19, 2009, 09:08:09 PM »
I'd think that all you'd have to do is get the 31 or 32 inch tire that your Sahara came with replaced with a 33 that matches your other four tires. You can then put it on the stock spare carrier. From everything I've read, you can put a 33 on there without issues. I've even heard of some guys running 35's on there, but that's a fair amount of weight to hang off of that sheet metal.
That might be worth trying. Okay, dumb question time, I got the tires with the jeep so where in Calgary is the best place to buy procomp tires and rims?
Offline LAHAL
« Reply #46 on: June 19, 2009, 09:09:17 PM »
33's on stock tire carrier on JK is no problem. Some guy here was running a 37 on it for a while.
LAHAL is confirmed for Sunday.
I'll be bringing my better half, and my fuzzy little friend. It will be my fuzzy little friend first time 4x4ing, she better not make a mess in the back.
Offline LAHAL
« Reply #47 on: June 19, 2009, 09:10:21 PM »
National 4wd has some for sure. They are across the street from Blackfoot Motorcycles.
fuzzylizard
« Reply #48 on: June 19, 2009, 09:22:17 PM »
Cool, thanks. Not sure how quickly I can get a tire, so probably won't be out Sunday.
Offline slimbeam
« Reply #49 on: June 19, 2009, 09:26:32 PM »
I'll be there for sure to run midship, prerun  aswell
« Last Edit: June 19, 2009, 09:35:19 PM by slimbeam »
« Reply #50 on: June 19, 2009, 09:58:00 PM »
Talk real nice to the guys at National.  They "may" be able to hook you up in time.
« Reply #51 on: June 19, 2009, 10:03:27 PM »
This sucks, I would love to join you guys, but I don't have a full-size spare. the rear tow-point I can take care of tomorrow, but I am not sure where to purchase or how to attach a 33" procomp tire. Is a full-size spare a usual requirement for these kind of runs?
i was in your same spot 3 months ago .. just go post something in the needed section someone might be nice and lend you one for the day .. thats what buddy did for me
as for 33 it will fit on the back of a TJ  and if you have a JK a 35 will fit there as well .. ull just have to give your door a bit of a slam to close it .
« Reply #52 on: June 19, 2009, 10:12:51 PM »
National, Modern...even "mainstream" tire places may be able to get you what you need.
A wheel and tire that match what you're running for the other four are ideal. Then you can run a 5 tire rotation. If you can't get that, just about anything that 's a 33" that will mate up with your JK's 5 on 5 bolt pattern will "git 'er dun" when push comes to shove.
« Reply #53 on: June 19, 2009, 10:28:20 PM »
 a can of ether does a good job will popped beads .. trust me i know i had both drive side tires come off 3 weeks back
1 spare isnt always enough ..
and in my case i didnt even have my lock nut socket with me so i had no choice but to get them back on the rims .. full of mud and water and snow
still got me home
 ;D
« Reply #54 on: June 19, 2009, 10:50:27 PM »
still got me home
 ;D
For sure. The insistence on a full sized spare is more about "oops" that seem to result sidewalls getting torn open. A lot of us carry cans of ether, plug kits, compressors...you name it. But there's some things that you just can't fix on the trail. :o
LRH4X4
« Reply #55 on: June 20, 2009, 03:42:27 PM »
Got the jeep in running condition so will see you at Mclean creek tomorrow hope to get rid of this cabin fever ::)
« Reply #56 on: June 20, 2009, 03:43:35 PM »
Im out. :(
« Reply #57 on: June 20, 2009, 05:26:31 PM »
Like broken valve stems on those new JK's with their sensors and stuff...   That would never happen... oh wait... it did TODAY.   Hopefully, you can get it fixed before tomorrow.
Anyone got an extra full size spare to fit a JK so the W Squared can join us?
« Reply #58 on: June 20, 2009, 06:38:13 PM »
W square messed his valve stem .. just change it for a normal stem all its going to do is set off a little lite on your dash no biggy .
« Reply #59 on: June 20, 2009, 06:49:22 PM »
Not sure if it will fit. The JK valve stems are metal.
