Author Topic: 95 xj tranny clunk  (Read 1861 times)
Offline Pookapotamus
95 xj tranny clunk
« on: June 18, 2009, 09:53:27 PM »
so my wife's xj has a clunck when you put it in gear or on the highway when you let off and on the gas. i am thinking ujoints although they seem fairly tight what does every one else think?
Re: 95 xj tranny clunk
« Reply #1 on: June 18, 2009, 10:02:38 PM »
u joints lol.  driveshaft something or other.
u joints shouldn't be 'fairly' tight. if they move at all they are bad......
Offline fug
  • Airdrie Pick n Pull
« Reply #2 on: June 18, 2009, 10:31:39 PM »
Any play on the rear pinion?  or at the tcase?  or ujoints
Fug
TJ Rubicon
Offline jandh
« Reply #3 on: June 18, 2009, 10:59:56 PM »
I thought the Clunks where all part of the fun
...it's just not the same without em ;)
Also try checking your motor mounts or the tranny mount
1991 YJ
« Reply #4 on: June 19, 2009, 07:53:30 AM »
everything is a little loose under there and since its for the wife i have to make it purr like a kitten, well off to napa i go! ::)
Offline ottawajeep
« Reply #5 on: June 20, 2009, 05:55:54 PM »
I've got the same noise under the same conditions, 94 XJ and can't pinpoint it, my u-joints arn't loose at all. :-\
Offline esi
« Reply #6 on: June 20, 2009, 11:47:28 PM »
The noise could be wear in your diff, between the ring and pinion teeth.
Formerly of Boots & Boost Inc
Offline S-FLY
  • '94 XJ
« Reply #7 on: June 21, 2009, 09:48:54 PM »
Mine does the same thing on the highway.  It's wear/play in the rear carrier inside the diff.
ve1sly
« Reply #8 on: July 02, 2009, 08:29:24 AM »
ok so i changed the fluid in her tranny cause it was black and flowed like water, gave it a new strap kit on the diff checked all the u joints and it still clunks quite hard going into drive.
is there anything else i can do?
« Reply #9 on: July 02, 2009, 08:38:51 AM »
sounds like an excuse to regear and run bigger tires :D
Offline slimbeam
« Reply #10 on: July 02, 2009, 09:06:57 AM »
if its not the u joints it could be a trany problem, oil shouldn't be black in a automatic trany, did it smell burnt, maybe the bands are loose
Offline S-FLY
  • '94 XJ
« Reply #11 on: July 03, 2009, 07:52:46 AM »
And an ARB air locker while I'm at it.  :D
ve1sly
« Reply #12 on: July 09, 2009, 08:51:18 AM »
the pinion has a little slack in it, but the clunk seems more exesive for that amount of play, it does idle high when you first start it but it does calm down, but does not seem to make a difference for the clunk.
« Reply #13 on: July 09, 2009, 09:43:42 AM »
hmm well this is my wifes and it has not been lifted the only thing that has been done to it is the swap of a dana 44 in the rear, and it does not sound like a body hit but i will crawl under and look into it maybe her tranny mount is shot.
