Author Topic: Help Bad Vibrations  (Read 868 times)
LRH4X4
Help Bad Vibrations
« on: June 20, 2009, 08:46:58 AM »
Hi Guys I have vibrations between 50 to 70 Kph then it disappears. it does not come through the steering column but shakes the whole jeep. Have had  the wheel balanced, right  tie rod end at pitman and track bar replaced also steering box and front rotors replaced by Emortal. Also had the rear axles replaced at the Gear Centre. at a loss to what may be causing the vibration any ideas out there.
ogilviexj
Re: Help Bad Vibrations
« Reply #1 on: June 20, 2009, 10:56:30 AM »
sounds like mine, check your drive shafts for dents etc. or it might be starting to come out.
