Author Topic: aw4 tranny fluid  (Read 1080 times)
Offline S-FLY
  • '94 XJ
aw4 tranny fluid
« on: June 20, 2009, 04:43:54 PM »
So I know you should only use Dextron III/Mercon for the AW4.  I was at Part Source today and they had Dextron V and VI.  I asked for Dextron III and he pointed at the Shell ATF which had smaller writing saying "For vehicles previously serviceable by Dextron III/Mercon".  The ATF part scares me...
Is this the right stuff I should be buying?  It was $15.99 for 4 liters. :o
ve1sly
Offline 2grand4u
Re: aw4 tranny fluid
« Reply #1 on: June 20, 2009, 07:04:58 PM »
ATF means automatic transmission fluid is that you Q
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #2 on: June 21, 2009, 03:26:51 PM »
I work at a parts store, maybe I could help you. That Shell ATF is probably a "Multi-vehicle" ATF. and will work just fine in the AW-4. I know i sell quaker state and castrol multi's that work in transmissions that require Dexron and Mercon III. The V and VI are meant for alot of newer vehicles, and you don't want that in your AW-4.
 Trans fluid is usually expensive, except for lower brands like the Walmart Tech-2000 stuff. Just make sure you get the right one!
84 Mustang GT-Built 351W 5spd
Offline S-FLY
  • '94 XJ
« Reply #3 on: June 21, 2009, 04:19:03 PM »
That's my question, basically is this Shell ATF the proper stuff.  Since it's like a Mercon/Dextron replacement.  I've rather use actual Mercon/Dextron III -- does anyone know where I can buy it?
ve1sly
Offline WagoneerXJ
  • Bagon Wagon!
« Reply #4 on: June 21, 2009, 04:44:18 PM »
Ford Dealer might still sell the Mercon III? just a thought
Offline S-FLY
  • '94 XJ
« Reply #5 on: June 25, 2009, 05:38:46 PM »
Just picked up a tranny cooler from PnP.  I wanna install this and change my tranny pan gasket and change the fluid, but still not sure if this is the right stuff to buy.
ve1sly
