Author Topic: Sway bar End Link  (Read 910 times)
YoungFluff03TJ
Sway bar End Link
« on: June 23, 2009, 11:30:47 AM »
Ok so I have a '03 TJ Sport and the sway bar links uhm...broke...so i took the oldies off and put the news in, but then the ball and bolt part that goes through the actual sway bar in jammed in there so tight they wont budge even when i use a 4 foot pry bar and vicegrips. any ideas as to how to remove them? theyre basically like a bolt through a hole but with a ball on one end.
Offline Evil-Jeep
Re: Sway bar End Link
« Reply #1 on: June 23, 2009, 11:53:30 AM »
So here is my method for these.
Use a hacksaw or sawzall to cut of the ball as close to the swabar as possable.
Tape an old large socket anysize over the spot where the ball use to be.
Take my large bench vice off the vice set it on a jackstand and place it so the top of the bolt is on one side and the socket is on the other.
Tighten the vice until it presses the bolt out of the sway bar and into the socket.
usually takes me 5mins...... longer if I use a hacksaw.
Buy disconnects or links without the ball and sockets as they break way too easily.
YoungFluff03TJ
« Reply #2 on: June 26, 2009, 04:14:29 PM »
Sir you are a gentleman and a scholar. I will do just that
« Reply #3 on: June 26, 2009, 04:15:45 PM »
Are you the guy that I sold that set to? Jeff's buddy?
Offline Chiram000
« Reply #4 on: June 29, 2009, 07:44:56 AM »
Just rent a pickle fork for separating ball joints.  Hit it with an over sized hammer a few times and it will come out nice and easy. You won't even have to destroy  anything in the process!
« Reply #5 on: June 30, 2009, 02:58:08 PM »
Just invert the bar and hit the end of the swaybar with a hammer. The link is tapered. The shock of the hammering will vibrate it loose. Same as a tie rod.
