Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
sye questions.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: sye questions. (Read 873 times)
BUKI
Talks waaay too much!
Project Fugly
sye questions.
on:
June 23, 2009, 05:57:21 PM »
been along time since last post. So HI
Ok, I originally lifted my jeep with a 4" RE kit. It came with everything. I installed the T-case lowering kit and the shims for the axle. But now I have a SYE in the T case and proper driveshaft from DSI. I have been driving it for well over a year now, and never thought any different. As of 10 minutes ago I was wondering if I was supposed to pull the lowering kit and the axle shims?
thanks
Mike
Logged
slimbeam
UberWheeler
4" RE,3"body,35"rubber,dana 44 rear,sye,KEW winch
Re: sye questions.
Reply #1 on:
June 23, 2009, 06:47:44 PM »
when I did my lift I had the T case lowered, but when I put in the SYE I took the spacers out so it was back like stock, I would leave the shims in though so the pinion is pointing at the T case
Last Edit: June 23, 2009, 06:49:39 PM by slimbeam
Logged
Fredduck
That CB Yapper
RIDE ON
Re: sye questions.
Reply #2 on:
June 23, 2009, 07:32:11 PM »
If the u-joint angles are good, the t-case drop doesn't bother you and it doesn't vibrate I'd leave it.
Logged
3.9 CTD - 7000R4 NP241c SSYE, Dana 44. 9 inch, 4.10's and 37's
BlackYJ
Re: sye questions.
Reply #3 on:
June 23, 2009, 10:16:30 PM »
With the length gained from the SYE you can remove the t-case drop but the shims are a must. Ideally the pinion should be pointing at the t-case yoke, but if you are a little lower that is not a problem. My pinion does not setup perfectly but works fine
Logged
BUKI
Project Fugly
Re: sye questions.
Reply #4 on:
June 24, 2009, 05:18:10 PM »
cool thanx for the info
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
sye questions.
