Author Topic: uh oh now what?  (Read 2728 times)
Offline Pookapotamus
Re: uh oh now what?
« Reply #15 on: June 24, 2009, 11:52:54 AM »
i think it is only the one layer i will check tonight.
Offline JENSSEN
    • Racing For The Cure
Re: uh oh now what?
« Reply #16 on: June 24, 2009, 05:54:43 PM »
ok so where is the best place to buy sheet metal?
Depending on how much you need I may have some chunks you can have :) or if its still driveable maybe just stop over with it and let me see if I may be able to whip up a quick patch panel PM me
« Last Edit: June 24, 2009, 05:56:37 PM by JENSSEN »
www.racingforthecure.ca
Offline 2grand4u
Re: uh oh now what?
« Reply #17 on: June 24, 2009, 07:03:40 PM »
if it were me i would grind off the rust because i have no way to get to a sand blaster, then i would paint it with some trim clade rust paint, then throw down a chunk of dimond plate with rivits, then bed line it it would look good and all your rust problems are gone.
thats what i would do. at big horn sheet meatal in canmore dimond plate is 2 buck a square foot i get a good deal though work but i'm sure you chould get it cheap some were.
Offline Duncan71
Re: uh oh now what?
« Reply #18 on: June 24, 2009, 07:20:48 PM »
I just patched up my floors on my YJ with sheetmetal from princess auto @ 22 bucks for 24" x 48" sheet using bad welds and machine screws.
Offline extremekustom
Re: uh oh now what?
« Reply #19 on: June 24, 2009, 09:45:03 PM »
What does it look like now after hitting hit with the wire wheel? From the one picture it looks like the left side by the wheelwell would be very thin after the prep work. Might want to consider cleaning and priming the current floor really well and then just skinning it.
Re: uh oh now what?
« Reply #20 on: June 25, 2009, 07:17:41 AM »
it does look pretty thin after cleaning and i totaly thought about skinning it but what do i put between the old and the new so that it does not hold water and just rust out the new? i actually think skinning it would be the best because after i bed line it, it will look sweet
