Author Topic: uh oh now what?  (Read 2756 times)
Offline Pookapotamus
uh oh now what?
« on: June 24, 2009, 07:26:35 AM »
so i stripped the interior of the jeep yesterday getting it ready for bed lining, the front is in really good shape just a couple of rust spots, but the back....
so how do i go about fixing this (cheeply)?  any suggestions? i was a mechanic not a body man so i am a little out of my element here. :-\
Re: uh oh now what?
« Reply #1 on: June 24, 2009, 07:48:51 AM »
I had a similar problem with my old CJ.  I did some research for my rusted floorboards, and used a product called " POR15"
It comes in a can, and you apply it with a brush. It hardens and supposedly stops further rust. It was pretty solid .
It can also be painted.
Another cheap alternative is to cut out the rusted areas and patch the holes up with sheetmetal and some rivets.
Re: uh oh now what?
« Reply #2 on: June 24, 2009, 07:49:03 AM »
POR-15  ;D
Offline JENSSEN
    • Racing For The Cure
Re: uh oh now what?
« Reply #3 on: June 24, 2009, 08:07:34 AM »
Nothing "cures" rot , it only slows it. Cut out the the steel around the holes, replace it by welding in new steel, take the flake rust off, if you want sandblast it, then coat it with a product like POR 15 or other rust inhibitor. If you prime it make sure you use a Top coat paint as primer is porous and will only start to rust again a month down the road.
www.racingforthecure.ca
Re: uh oh now what?
« Reply #4 on: June 24, 2009, 08:25:28 AM »
i am planning on using the same raptor kit that blair used to line his interior, will i still be able to if i use por 15?
Re: uh oh now what?
« Reply #5 on: June 24, 2009, 08:32:02 AM »
I don't see why not? I had my "butchered" POR-15 and 'ghetto sheetmetal" I can't weld worth a damn interior Rhino lined.
Re: uh oh now what?
« Reply #6 on: June 24, 2009, 08:40:37 AM »
ok so where is the best place to buy sheet metal?
Offline 01sahara
Re: uh oh now what?
« Reply #7 on: June 24, 2009, 09:08:18 AM »
My opinion
Correcting my earlier comment in the PM. Now I see the rust  sand blast the floor, get rid of the rust. Then fix any holes and use a good primer that etches to the metal. If that is just surface rust the sand blaster at Consolidated compressor will make fast work of it.  Gone. If the rust is deeper then you may have more holes to fix.
Be careful to tarp off the dash the sand will get everywhere.
Re: uh oh now what?
« Reply #8 on: June 24, 2009, 09:15:05 AM »
i took a wire wheel to it last night and found a couple more holes just little pencil sized ones. alot of it was surface rust, i do have a couple of holes to patch but what should i do about the small ones?
Re: uh oh now what?
« Reply #9 on: June 24, 2009, 09:24:24 AM »
You don't really need a lot of sheetmetal to fix your rust problems. A lot of shops that utilize sheetmetal  have "steel bins" and you could always get some fairly big pieces for your XJ. It's free! Might want to ask first though. Worst case scenario? Go to Crap Tire's autobody section. They have small sheets for under $25 called "u-fix it" and it should suffice; plus you get that "funny money" for buying crap there.
ps. You may have to hop in one of those steel bins and root around for an appropriate size of sheetmetal. DO NOT wear flip-flops!
joker
Re: uh oh now what?
« Reply #10 on: June 24, 2009, 10:02:27 AM »
dont plug em those are drainage holes :)  :P
Re: uh oh now what?
« Reply #11 on: June 24, 2009, 10:09:31 AM »
but if i plug all the holes it will float like the top gear boys did! ;D
Offline .:.Dingman.:.
Re: uh oh now what?
« Reply #12 on: June 24, 2009, 10:17:35 AM »
dana is this the xj I saw? or your wifes?
Re: uh oh now what?
« Reply #13 on: June 24, 2009, 10:18:46 AM »
its my xj, the wife has me fixing other problems on hers ::)
Offline Evil-Jeep
Re: uh oh now what?
« Reply #14 on: June 24, 2009, 10:55:51 AM »
If the XJ is like the Tj it should have the double layer of sheet metal on the floors, with a gap between the two. If so I would be more concerned about the rust you dont see on the in between the two layers. even if you sandblast and prime the top the rust may just eat the floor out from the under side.
