Author Topic: TPS?  (Read 742 times)
Offline BUKI
  • Project Fugly
TPS?
« on: July 01, 2009, 02:04:55 AM »
Ok, I have major issues with tps sensors.  I have tried all different brands from can tire autovalue, partsource, and oem.  I get approx. 3 to 6 months out of it before the jeep starts to buck under part throttle.  could there be an underlying issue that could cause a tps to go bad?  I am getting really frustrated this is my 12th.  and a new tps cures the problem.  The  jeep is 2.5 5 speed.  Any and all  suggestions would be very appreciated. will try anything.
thanx
oh also have swapped all other sensors except map, ordered it this week.  I just think the jeep is 15 years old and they should all be replaced (ie milage)
« Last Edit: July 01, 2009, 02:09:17 AM by BUKI »
Re: TPS?
« Reply #1 on: July 01, 2009, 07:35:58 AM »
Mike...throwing any codes at you?
Re: TPS?
« Reply #2 on: July 01, 2009, 10:31:50 AM »
ive seen some tps go bad from the engine being washed or just getting wet. id be sure to check the connectors for a good seal. does this jeep spend a lot of time in the mud and water?
Offline BUKI
  • Project Fugly
Re: TPS?
« Reply #3 on: July 01, 2009, 02:39:45 PM »
yeah, sorry its a 94.  SO no OBDII and no codes.  not even a tps code.  just bucking and sometimes power loss @ full throttle.  No mud/offroad, for a long time. BUT every time it does this I change the TPS just like I did today, and bingo works awesome again.
Offline TJ54
Re: TPS?
« Reply #4 on: July 01, 2009, 05:43:03 PM »
check the wires carefully, i went through the same thing. and I eventually found a bad connector at the tps end. I can't remember for sure but I may have spread the contact pins a little bit to get the good connection
