Author Topic: Dana 30 Gears  (Read 814 times)
Offline Mikes off road
Dana 30 Gears
« on: July 08, 2009, 02:23:09 PM »
I have a question that I hope someone knows the answer to. My son has a trail only 75 CJ-5 he has taken out the ring and pinion. The ratio is 3.73 in a low pinion housing. Will the ping and pinion out of a low pinion XJ dana 30 fit in the CJ housing. Or for that matter will and newer LP Dana 30 gear set fit.
