Author Topic: Can I fit 35's"  (Read 712 times)
Offline Duncan71
Can I fit 35's"
« on: July 08, 2009, 11:30:42 PM »
Got a 92 YJ w/ 4" RE lift.  Is 35s doable?  33s fit with zero issues so im thinking 35s will be fine, maybe a little rubbing at full flex/steer.  Opinions?
Re: Can I fit 35's"
« Reply #1 on: July 09, 2009, 07:11:11 AM »
You will probably need a 1" BL if you don't want rubbing or change over to TJ style flares as they increase clearance in the wheel wells by at least an inch
Re: Can I fit 35's"
« Reply #2 on: July 09, 2009, 08:36:04 AM »
TJ flares = good to go.  i have 4" springs 1" shackles and the bodylift. and i clear the iroks no prob
