Author Topic: Warning: Don't do this  (Read 3154 times)
« on: July 09, 2009, 03:49:29 PM »
http://www.moabjeeper.com/articles/general/listing.cfm?articleID=468&submit=Go
This has got to be one of the most unsafe this I have ever seen, and it's even more alarming that a magazine even printed this.  Connecting straps like this or using this as a method of attatching straps to your vehicle is entirely unacceptable and if you do this I doubt that anyone would pull you out of this was your recovery setup.
If you absolutely have to connect two straps, use a shackle.  The method that I prefer is to tie the two together using the loop ends, its a bit harder to get undone but there is no 5lb shackle that becomes a missile if it does break.
« Last Edit: July 09, 2009, 08:25:01 PM by fraserb1986 »
Re: Warning: Don't do this
« Reply #1 on: July 09, 2009, 04:20:36 PM »
there is an error on the link for some reason but nevertheless....
Please NEVER, NEVER, NEVER use a shackle to connect 2 straps together.... Like you mentioned ... make a loop with the other strap and use a small piece of wood in the loop when it gets tight so you can undo it easy after the pull.
If you need to know how .. I will show you guys at the next meeting.
Using a shackle = DEATH...
it's like putting a nut at the end of a rubber band 100X bigger... It would hurt if you get the nut in the forehead.... Imagine a shackle...
« Reply #2 on: July 09, 2009, 04:22:11 PM »
Linky no worky...404 error.
You're 100% correct about connecting loop ends. If you put a short stick in the middle, it prevents them from getting too tight and you still avoid installing a five pound missile into your recovery system. Shackles between tow straps = bad juju
Edit: Looks like I said the same thing as Dom, but was slower.
Caddy
« Reply #3 on: July 09, 2009, 06:13:51 PM »
http://www.moabjeeper.com/articles/general/listing.cfm?articleID=468&submit=Go!
about half way down the page they show a picture using 2 tow hooks bolted together to attach 2 straps.
Offline mrjeep4
  • Don't forget your Super Safety Suit
« Reply #4 on: July 09, 2009, 06:39:59 PM »
wow ...       ummm    that's a nice slingshot setup ...
03 Rubicon 6" full traction long arm on 35's, warn 9ti winch,custon flat fenders and side rails
« Reply #5 on: July 09, 2009, 07:20:47 PM »
Wow.   :(
« Reply #6 on: July 09, 2009, 08:25:22 PM »
Fixed link in the OP
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #7 on: July 09, 2009, 08:27:32 PM »
« Last Edit: July 09, 2009, 08:29:22 PM by RckyMtnTJ »
98 TJ 4" lift + goodies
Caddy
« Reply #8 on: July 09, 2009, 08:45:25 PM »
I am kinda amazed that they think this is a good idea
« Reply #9 on: July 09, 2009, 10:29:38 PM »
Not to mention the "belittling" of the guy without tow hooks.
Sure, let's all belittle the people who are beginners.  That'll teach them to try to join in with the rest of us gods.  ::)
Offline GiS
« Reply #10 on: July 10, 2009, 07:59:07 AM »
Carry an old hammer or hatchet handle...That's what Vinman taught me!!
Offline rangerdanger
« Reply #11 on: July 10, 2009, 08:10:43 AM »
Maybe instead of belittling the guy with no hooks and being a jacka$$ they could bolt those hooks to his jeep and help a newbie out.
Lethbridge Coulee Kruzer
« Reply #12 on: July 10, 2009, 11:20:05 AM »
ok maybe someone can explain to me, why is this bad?
i think its a great idea.  with the access to hooks on both ends like that you can easily find something on the undercarriage like a swaybar or tie rod that you can easily loop that tow hook around for easy access.   its pretty hard to loop a shackle around those things; you hve to like, unscrew it and stuff. this looks much quicker.
just jokes......... straps looped together = good times.  shackles + multiple straps = bad news bears.
also,
i'm pretty sure most newbies will learn rather quickly on this forum what 'proper tow points are' as they are usually posted at least once a week in some post about some run somewhere..........
Offline cotaman
« Reply #13 on: July 10, 2009, 10:54:06 PM »
somebody was not thinking on that fire crew......   a loaded fire truck is way beyond working load limit of the average shackle.....  and the draw bar on a tractor can take a huge load... so the shackle becomes the weak point in the equation if they are using large strap with a breaking strength of say 20000 to 30000lbs .......    it is unfortunate that someone who risks their life to save others pays the ultimate price for someone's ignorance or stupidity....just my two cents.....
however... sometimes situation dictates creative thinking  ::) but has to be done safely and be approached cautiously  8) ......  ie the recovery of my jeep after floppying it on  :o  a post S&S run in 07.....
by the way if anyone has pics of that recovery they would be greatly appreciated  :)
Offline Fredduck
  • RIDE ON
« Reply #14 on: July 11, 2009, 09:20:28 AM »
I just noticed a link in that article for a potential new product invented by an offroader.
Good idea, hopefully some outfit will pick it up.
http://www.rockcrawler.com/features/newsshorts/04april/winchball.asp
