Author Topic: Welders!  (Read 1416 times)
Offline Aspirated
Welders!
« on: July 15, 2009, 07:31:44 AM »
Any Welders out there? Im looking at putting some ProComp recovery hooks on the front of my YJ until my Warn front bumper comes in next month.
1998 XJ
2008 KK
Re: Welders!
« Reply #1 on: July 15, 2009, 07:47:07 AM »
There is no need to weld the hooks on.  There are 2 bolt holes in the frame but you have to remove the plastic cover to get at the second one
Offline Aspirated
Re: Welders!
« Reply #2 on: July 15, 2009, 08:32:02 AM »
Yeah. This is a "new to me" jeep, the tapped bolt holes in the front of the frame arnt going to work, the rear one is essentially just a hole into the frame itself. The fella that had this JEEP before me had some modifications to the front frame area.
1998 XJ
2008 KK
Offline Aspirated
Re: Welders!
« Reply #3 on: July 15, 2009, 08:52:29 AM »
Ill make the Warn Bumper work....  ;D
1998 XJ
2008 KK
Re: Welders!
« Reply #4 on: July 15, 2009, 09:13:58 AM »
drill out the hole mounts on the bumper, drill out the stripped threads in the frame. re tap, use larger bolts.  welding that puppy on there would make you stupider than the guy that fawked up your mounting points in the first place ;)
Offline Aspirated
Re: Welders!
« Reply #5 on: July 15, 2009, 09:35:09 AM »
Yeah,m i would spend the time with the drill and the tap set on the bumper to ensure its mounted properly, In regards to the tow hooks, i was just going to mount them for the time being, then cut and grind them off when needed. But i agree, if you're going to spend the dough on a good front it needs to be installed correctly.
1998 XJ
2008 KK
Offline Fredduck
  • RIDE ON
Re: Welders!
« Reply #6 on: July 16, 2009, 07:33:08 PM »
helicoil the holes
Re: Welders!
« Reply #7 on: July 16, 2009, 07:39:44 PM »
helicoil the holes
i don't think thast necessary...... you can use a larger bolt and drill out the hole. the helicoils are more suited for things like brake calipers/knuckles aren't they?
Offline Fredduck
  • RIDE ON
Re: Welders!
« Reply #8 on: July 16, 2009, 08:11:02 PM »
depends on if you need the stock size or not
Offline slimbeam
Re: Welders!
« Reply #9 on: July 16, 2009, 09:41:13 PM »
get a grade 8 or better "fine" tread bolt with a nut the size of the hole and use in the drilled out hole
« Last Edit: July 16, 2009, 09:43:30 PM by slimbeam »
