Author Topic: CJ Sway Bar - OPTIONS?  (Read 897 times)
Offline Mingler
« on: July 29, 2009, 01:51:46 PM »
Folks,
I'm looking at putting a sway bar on the CJ since 90% of my driving is pavement (Don't worry, I'll use disconnects).
At any rate, I need to find a sway bar and was wondering if anyone has any experience in this department and might be able to guide me in the right direction for what will work?
Do I need to specifically find one off a CJ or are there other options out there that I can use?  TJ maybe?
I'd be interested in hearing your experiences etc.
Cheers
Re: CJ Sway Bar - OPTIONS?
« Reply #1 on: July 29, 2009, 04:29:00 PM »
i didn't know CJs came with sway bars.................... i don't run one on my Yj and i like it...........
Offline AMCJeep
« Reply #2 on: July 29, 2009, 10:21:53 PM »
81+ had sway bars. Mine are long gone but you will need a CJ sway bar as they are bent up for the narrow CJ frame and front track.
03 Ram 2500 QC, LB, 5.9 CTD
Offline rangerdanger
« Reply #3 on: July 30, 2009, 03:10:00 PM »
I have one off my '82 CJ-7 I took it off when I lifted it as it rode like a dumptruck with it attached. I run a 4 " lift and 35" boggers and don t noticed any more sway than with no lift and swaybar attached.
Lethbridge Coulee Kruzer
« Reply #4 on: August 05, 2009, 01:50:04 PM »
You can antirock it as well.
Get frame with measurements I can recommend the correct currie antirock to go with. They are universal and can be mounted in just about anything.
