Author Topic: hids are flickering  (Read 949 times)
Offline yukonwheeler1
hids are flickering
« on: August 06, 2009, 08:09:55 AM »
i just had some hids installed and the drls are flickering and there is a loud buzz in my jeep, when i turn the headlights on both the buzz and the flicker goes away does anyone have a fix for this problem
Re: hids are flickering
« Reply #1 on: August 06, 2009, 08:24:27 AM »
what vehicle and year?  it's simply because these headlights use much less power (wattage) and can trigger problems with sensors and stuff (similar to what happens when you have a burned out bulb somewhere).  sometimes all it takes is a resistor soldered on or a computer programming from stealership.
« Reply #2 on: August 06, 2009, 08:31:46 AM »
2007 jk they had the flicker problem when the highbeams were on but fixed that problem i just know nothing about electrical so I'm lost in that department
Corey
« Reply #3 on: August 06, 2009, 01:40:27 PM »
My buddy had the same problem same year you need a relay to stop the buzzing
« Reply #4 on: August 06, 2009, 05:59:09 PM »
HID's flickering or buzzing is a common problem with JK's. The CANBUS systems that runs the electrics doesn't play well with HID's. Apparently you'll need to put a capacitor into the harness for your HID's in order to even things out a wee bit.
I can't recall the details (didn't look all that close at them since I don't really want to go with HID's in my JK), but if you search through the electrical section on project jk forums, I'm sure you'll find a hockey sock full of info on how to put HID's in your JK for that riced-out look  ;D
