Author Topic: a/c clutch  (Read 777 times)
Offline Elsifer
a/c clutch
« on: August 13, 2009, 10:33:30 AM »
The dealership only has a part# for the whole compressor assembly $700+ !!!
I just need a clutch and pulley. Anyone done the leg work on this, and have some part#'s?
Its for an 04 Rubi, so I will go out on a limb and say any late generation of the 4L with a/c will be the same model of compressor.
Cheers
Chris
VA6CPL
Jeepless....
Re: a/c clutch
« Reply #1 on: August 13, 2009, 03:11:00 PM »
Try Polar Mobility. They can get you one if you give them the make/model of your compressor.
Offline Elsifer
Re: a/c clutch
« Reply #2 on: August 13, 2009, 10:59:28 PM »
And whose part numbers are those?
The dealership was quite helpful in trying to find a reman part, or looking at other models to cross-reference an interchangeable part. To no luck.
Going to get a serpent belt for non-a/c and just ignore it for now. I don't want to pull the compressor just to find a make+model on it to get parts. The whole evacuate and recharge the refrigerant issue. So going to run without till I can rustle up what i need.
Thanks though, Clay's suggestion will require some legwork, next week for that.
VA6CPL
Jeepless....
90YJGIMP
Re: a/c clutch
« Reply #3 on: August 14, 2009, 06:34:27 AM »
I had my A/C Clutch replaced on my YJ a couple years ago. Heres a link to the company that supplied the parts. Worth a shot.
http://www.fourseasonsradiator.net/page/page/1766043.htm
