Author Topic: ? Staun internal bead locks with bead lock rims.  (Read 4470 times)
tcharon
« on: August 16, 2009, 01:15:16 PM »
Has anyone had any experience with installing Staun internal bead locks inside any type of regular bead lock wheels? I happen to have Poison Spyder Customs, Spyderlocks and already have a set of Stauns. I've burped air from the Spyderlocks so want to use the Stauns to help with the inner beads and be a run-flat, but have heard the rims will cause rips in the Staun tubes. Can anyone help with info?
tcharon
Re: ? Staun internal bead locks with bead lock rims.
« Reply #1 on: August 16, 2009, 02:17:37 PM »
It was my understanding that if you had good beadlocks installed properly you couldn't "burp" a tire or lose a bead without pretty much destroying the tire or rim.
Again, as I understand a beadlock has a ridge inside that the locking ring pushes the bead against, so there shouldn't be exposed bead that the Staun can push against, it would more likely contact the sidewall and cause distortion, though I suppose it may contact the rest of the locking ring.
Just my understanding of the mechanics of it.  Perhaps one of the really tech guys could enlighten further?
Thanks, they can burp at low air press but don't loose the bead. Staun says most rims will cut the tubes. Just hopeing someone has had experience.
« Reply #2 on: August 17, 2009, 09:19:05 PM »
i think haveing one or the other would be a better idea. using both wont really work. if the beadlock rim is the usual design. ive installed a few sets of stauns as well, and pretty much all of them leaked. and everyone else that has installed them had leaks as well. once you fix the leaks though they seem to hold up. the problem was you had to use the special tubes from staun, which is not next door to your sister. you gotta order them in and wait... wait... wait.
i think there are a couple new companies using hte same idea now but with motorbike tubes, which you can pick up your self at any bike shop.
the staun is nice for the double beadlock system, the regualr rim beadlock is nice for simplicity sake and you can do them yourself at home.
tcharon
« Reply #3 on: August 18, 2009, 09:19:48 AM »
Hay, thanks for the input. I do have one extra tube and would like to have the advantages of both. Makes me feel safer on the trail and may reduce the need for that big spair. I will try that cycle tube idea if can find the fully threded stem. How did you fix & what's the leaking problem?
« Reply #4 on: August 18, 2009, 10:47:10 AM »
Staun beadlocks will not work with those mechanical beadlock wheels.
Leaks are often caused by not seating the valve stem properly.
A little windex or water should help it slip into place properly. Some wheels require you to shape the air channel to contour the wheel. 2 grommets are included, make sure the correct one is used for that wheel.
And/or
Tires, some tires have sharper inside bead edges, easy enough to smooth them down so they can't cause any problems.
I have some spare tubes if you wreck one. Other sizes are only about a week away for shipping.
Offline SwampRat
« Reply #5 on: August 18, 2009, 11:04:15 AM »
I use the Staun internal bead locks and had numerous leaks.  Once we got the correct procedure to install them from Staun, I haven't had any more leaks or problems.  I do agree that you should use one or the other, not both.
I HATE mud and snow!!!!!!!
VE6DLR
VA6DLR
tcharon
« Reply #6 on: August 18, 2009, 11:51:34 AM »
Thanks for that, but I just don't see why I can't have both advantages. Nothing I saw inside my rims was sharp enough looking to cut the tubes.
« Reply #7 on: August 18, 2009, 12:41:50 PM »
The Staun beadlock case does not reach the inside of the tire bead and it seats irregularly against the metal of the beadlock and blows tubes.
tcharon
« Reply #8 on: August 18, 2009, 01:02:58 PM »
Any fix you know of?
« Reply #9 on: August 18, 2009, 01:19:04 PM »
Hutchinson DOT Dual Beadlock
drrrrroooooooooooolllll
« Reply #10 on: August 18, 2009, 01:26:35 PM »
No "fix", they're not really broken, just not designed to be installed with other products inside a tire.
tcharon
« Reply #11 on: August 18, 2009, 01:37:08 PM »
The Hutchinson is nice but doesn't act as a run flat, not in 9" and big bucks. Still looking for a way.
« Reply #12 on: August 18, 2009, 01:52:55 PM »
i dont know what you mean by run flat.
why do you need 9" ?
and yea they were pricy when i got my walker evans, probably the price of spider/staun combo.  if i remember correctly they were about US$100 more each
tcharon
« Reply #13 on: August 18, 2009, 02:08:49 PM »
Run flat is where your tire goes flat and you can still run on the flat cuz the inner tube & balistic nilon caseing holds the rig off the rim beads cuz it still has air in it. I already have both rims & Stauns & needed 9" cuz my Stauns are for 9 to 10.5" rims and wanted to have more sidewall outboard, 8" would have been too narrow for my Stauns. But, Thanks.
« Reply #14 on: August 18, 2009, 02:10:14 PM »
I had one leak in mine after a year and a half... National fixed it and it's been good ...
I got a set of Staun for the GF also ... I like them lots... Thanks Frenchy ;D
