Author Topic: sway bar disconnects  (Read 1103 times)
« on: August 24, 2009, 09:32:10 PM »
Tweaked one of the sway bar mounts that is right beside the lower track bar mount and now the lower bolt is sitting at a slight off angle. The sway bar disconnects are now really stubborn to take off. Who makes a sway bar disconnect that is forgiving and easy to use. the ones i have now are simular to re gen1 types. They are on an xj with 4.5 of lift. What brand should i get and what do you guys use?
Offline fug
  • Airdrie Pick n Pull
Re: sway bar disconnects
« Reply #1 on: August 24, 2009, 11:26:27 PM »
Currie Antirock... never disconnect a sway bar again AND be more stable on climbs & side hills AND flex like crazy still.
Fug
TJ Rubicon
