Author Topic: Got wet  (Read 1822 times)
Offline Rhoc
Got wet
« on: August 24, 2009, 10:35:23 PM »
I have a 92 YJ (2.5 inside) that has given me no real problems till last week.  I was out in McLean and got a little wet, bout 4 feet  wet.  My YJ is lifted and the water was only inches below the intake.  Stalled in the water got pulled out and started after a little wait.   On the way home I noticed it was surging a bit.  After 2 or 3 more in town short trips it was stalling when ever I let up off the gas or when I pushed in the clutch.  I pulled the cap to inspect looked OK replaced with new cap and rotor just for good measure.  While I was in there I changed plugs also.  Still the problem wasn't getting better.  Now it will not start unless I floor it almost like it is flooding, runs good cold but same problem as at first when it warms up.  Drained the fuel replaced with new, changed fuel filter, same problem. Ran a computer on it, said O2 high so changed sensor.  Still the same. Lots of carbon out exhaust when I change gears.  Not sure what to do next.  Anyone have a similar problem or know a possible fix?
« Last Edit: August 24, 2009, 10:58:25 PM by Rhoc »
Re: Got wet
« Reply #1 on: August 24, 2009, 11:05:14 PM »
What does the oil on the dipstick look like?
Offline Shearcon79
Re: Got wet
« Reply #2 on: August 24, 2009, 11:15:36 PM »
I think that I would inspect the vacuum lines.  I had problems with my YJ(4.0) stalling out and surging on the highway.  I found out that my vacuum lines from my valve cover to my intake were damaged.
Good luck with the problem
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
Offline Rhoc
Re: Got wet
« Reply #3 on: August 31, 2009, 09:27:18 PM »
The oil is fine will check the vacuum lines.
Offline mike s
  • Good times!
Re: Got wet
« Reply #4 on: September 01, 2009, 12:03:14 AM »
Plugged exhaust could give you grief. Muddy water?  But more likely vacuum leaks leaning out idle. Try cycling key on-off-on-off-on, (not cranking or running) and count the blink codes. Might be a hint there.
oldEnuff2NObetter
but still can't help myself
Offline Rhoc
Re: Got wet
« Reply #5 on: September 07, 2009, 12:31:06 PM »
Will try.
Offline Shearcon79
Re: Got wet
« Reply #6 on: September 09, 2009, 09:54:54 PM »
Any luck with this?
Green 94 4.0 YJ :
Offline Rhoc
Re: Got wet
« Reply #7 on: September 13, 2009, 09:55:40 AM »
No still has the problem.  Haven't had a lot of time to work on it.  I changed the TPS just in case but the same issues.  Now the check engine light is on.
No idea
Offline Mikes off road
Re: Got wet
« Reply #8 on: September 13, 2009, 07:07:47 PM »
Same thing happened with my Ford. It ended up being water that leaked into the fuel system. Ended up draining the tank then refilling with five gallons and some gas line antifreeze to remove any moisture in the system. Not sure if it will work for you but it can`t hurt.Also change the fuel filter for good measure.
