Author Topic: 4 lo is a no go  (Read 1026 times)
YoungFluff03TJ
4 lo is a no go
« on: August 25, 2009, 05:24:35 PM »
So i put on my 3" lift for my TJ with a T-case Drop, all is fine. I had clearance issues with my shifter going into the lower gear (2,4,R) so i took the boot off and its perfect. But...4 low wont go into 4 lo. 2, 4 Hi Neutral are all fine....do I just need to shave the plastic back a bit same as the shifter? or is something more drastic neccesary?
Re: 4 lo is a no go
« Reply #1 on: August 25, 2009, 08:59:05 PM »
i think you solved your own problem.............
Re: 4 lo is a no go
« Reply #2 on: August 26, 2009, 09:46:01 AM »
No, you just need to adjust the rod to correct the placement of the shifter throw.
YoungFluff03TJ
Re: 4 lo is a no go
« Reply #3 on: August 26, 2009, 11:27:15 AM »
i just like to consult experts before i hack  the inside of my child
Offline LifesGrand
Re: 4 lo is a no go
« Reply #4 on: August 26, 2009, 03:57:24 PM »
I think what Bnine is explaining to you is do not cut any plastic, crawl underneath the jeep, find the linkage adjust screw & muck wit it.
« Last Edit: August 26, 2009, 04:00:06 PM by LifesGrand »
95 ZJ v8 Ltd.
