Author Topic: Trailer Axle flip  (Read 3119 times)
Offline Grease Nipple
Trailer Axle flip
« on: September 08, 2009, 09:21:41 AM »
Has anyone "flipped" axles on a trailer? I have a older (circa 1978) travel trailer. it is very low to the ground. it has 2 axles with trailer brakes on one. I  have heard you  don't really "flip" the axles but weld new perches on the top of the axle? is this a difficult job? time consuming?
Re: Trailer Axle flip
« Reply #1 on: September 08, 2009, 12:06:40 PM »
i paid $400 to have it done at Calgary Spring.
Offline The Machinist
  • I’m with stupid!
« Reply #2 on: September 08, 2009, 03:46:27 PM »
I just flipped my axle and used the same spring perches on my scamper camper.  Worked good until I caught a homeless guy sleeping in there, then it was time for the scamper camper to go!
« Reply #3 on: September 08, 2009, 04:46:26 PM »
You shouldn't "flip" the axle and use the same perches. The axle has an upward bend in it to compensate for how it will bend when the weight is on it(downward). If you flip it then you will have the arch the wrong way and the tops of the tires will start to lean in causing uneven wear.
The proper way is to install new perches on top of the axle and then bolt the axle under the springs.
« Reply #4 on: September 09, 2009, 09:55:15 AM »
Thanks cLAY, thats what I heard awell,
Hey Johnny! feel like welding some new perches?
Is there anyone that can fix the weld job me and JohnnyC are about to butcher?
« Reply #5 on: September 09, 2009, 10:52:17 PM »
booger welds and bud light lime eh?  i don't think that lil' buzz box will do the trick................. maybe this is justification for you to buy a welder :D i know your neighbour would put it to good use!
