Author Topic: Saturday the 12th or Sunday the 13th  (Read 8193 times)
Xero
Re: Saturday the 12th or Sunday the 13th
« Reply #30 on: September 12, 2009, 11:37:31 PM »
Was a pretty fun run there guys! Thanks for the tips and all that whenever I asked!
Offline jeeptastic
« Reply #31 on: September 13, 2009, 10:19:28 PM »
Mike I am working on getting a link up for you.
Jen can you tell Ryan that the rattle that we asked him about on Saturday morning that we thought was a rock in the brake turned out to be my front drive shaft. I am running two wheel drive for a while until we get that fixed.
Thanks again for everyone who came out Saturday.
Offline jenn1981
« Reply #32 on: September 13, 2009, 10:22:21 PM »
I will let him know Richard...did you figure out your check engine light??
2008 JK Rubicon
Offline jeeptastic
« Reply #33 on: September 14, 2009, 10:17:26 AM »
I forgot to ask about the engine light. I think I have to find someone with a computer and hook up my Jeep to see what the engine light meant. When I do find out I will let you know.
« Reply #34 on: September 14, 2009, 10:51:31 AM »
pull the trouble codes.  do you have a haynes manual?
turn the key from 'off' to 'on' three times in a row. do not turn jeep on. cyle it on, then off, on then off, on then off. on the third time, keep it 'on'  in the odometer display the computer will flash you numbers, something like P0135 or similar. these are trouble codes. record all these 'trouble' codes, and hit the net. or post them up. someone will tell you what they mean.
Offline mike s
  • Good times!
« Reply #35 on: September 14, 2009, 12:28:37 PM »
Tried that on the trail when it came on and the engine stalled. Too new for that 'ol chrysler trick. Earlier ones will blink two digit trouble codes. You'll need a code reader or scanner to figure that one out. DON'T disconnect the battery till you get the code(s) read.
oldEnuff2NObetter
but still can't help myself
« Reply #36 on: September 14, 2009, 01:13:40 PM »
sure does mike ;) your engine shouldn't stall out cause its never on to check the codes ;)
works in my GFs 2001 and moms 98, as well as my 02 ram, why wouldn't work in his?
if you want you could probably drop by this week, we can hook it up to my neighbours computer, i know he loves to play with his new toy hahahaha it'll tell ya all sorts of good stuff for hte jeep :D
Offline jeeptastic
« Reply #37 on: September 14, 2009, 11:59:29 PM »
That would be Fantastic John. I will send you a pm. Thanks.
