Author Topic: Oil leaking??  (Read 685 times)
binjeepin
Oil leaking??
« on: September 10, 2009, 09:40:40 AM »
I just picked up a 90 YJ with the 2.5 4cyl. It is leaking oil into the air cleaner box through a little hose that I thought ran from the PCV valve. I took the 'valve' out only to find that it is only a vent type thing. No check valve or ball in it at all. I suspect some blow back from a posibble valve problem. Any suggestions before I go and tear the head off of this thing and get a valve job done??
Offline LifesGrand
Re: Oil leaking??
« Reply #1 on: September 10, 2009, 10:51:24 AM »
I was just reading an artical on this last week, this is based on the 4.0L, but might steer you in the right direction???
HTH..
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=257985
95 ZJ v8 Ltd.
binjeepin
Re: Oil leaking??
« Reply #2 on: September 11, 2009, 05:40:34 PM »
That sounds like an easy fix and describes what is happening woth mine. I think that it should work on the 2.5 as they share similar systems.
