Author Topic: XJ Alternator?  (Read 3903 times)
Offline Mudhawg
  • Rig Life
XJ Alternator?
« on: September 20, 2009, 07:11:54 PM »
how the heck does it come out? got the 3 bolts out but seems ever bracket has to come off to get it out? anyone know? its agrivated me  >:(
Re: XJ Alternator?
« Reply #2 on: September 20, 2009, 07:22:05 PM »
There's a size for every removal
« Last Edit: September 20, 2009, 07:30:41 PM by Vinman »
Offline Mudhawg
  • Rig Life
Re: XJ Alternator?
« Reply #3 on: September 20, 2009, 07:25:55 PM »
trust me vince that thought has already crossed my mind
Re: XJ Alternator?
« Reply #4 on: September 20, 2009, 07:29:25 PM »
While you're at it, remember to flip it so the mud and stuff collects in the (new)bottom away from the brushes.
Offline Mudhawg
  • Rig Life
Re: XJ Alternator?
« Reply #5 on: September 20, 2009, 07:32:44 PM »
how do i flip it?
Re: XJ Alternator?
« Reply #6 on: September 20, 2009, 07:36:12 PM »
Offline S-FLY
  • '94 XJ
Re: XJ Alternator?
« Reply #7 on: September 21, 2009, 08:00:41 AM »
They're a pain in the arse to get out.  There's a big bracket that it bolts to that has to come out too and there's a bunch of big bolts and nuts holding that bracket in.  Reassembly takes some effort too.  Have fun.  :)
ve1sly
Re: XJ Alternator?
« Reply #8 on: September 21, 2009, 09:42:41 AM »
how do i flip it?
You need a special bracket to flip it...
Doug,... when all the bolts are out... you can pry it out....it's a pain.
Offline Mudhawg
  • Rig Life
Re: XJ Alternator?
« Reply #9 on: September 21, 2009, 01:34:04 PM »
ya im gunna continue workin on it in a bit i swear if i undid the motormounts a bit it would come out if i lifted the motor but thats a PAIN
Offline kitimat Rich
Re: XJ Alternator?
« Reply #10 on: September 21, 2009, 03:21:03 PM »
repair it and seal it up. the brushes are full of mud or worn out a new brush holder assy is $25.00
« Last Edit: September 21, 2009, 03:27:29 PM by kitimat Rich »
Re: XJ Alternator?
« Reply #11 on: September 21, 2009, 04:11:02 PM »
Yep.. back in the days Rich did mine... it has been running stong since then.
Offline dubbleJs
Re: XJ Alternator?
« Reply #12 on: September 21, 2009, 05:16:36 PM »
The bracket bolted to the motor doesnt have to come out mang....get out the big pry bar and save yourself some work! I've found some easier than others to come out, especially when the motor mounts are pooched   :P
Re: XJ Alternator?
« Reply #13 on: September 21, 2009, 07:37:35 PM »
I think he meant re-index the case, see below.
"Rich(Capt Crunch) gave me a tip that works great. The way the alt is mounted puts the brushes at the bottom of the alt and the vent holes at the top. This causes mud/water to settle at the bottom of the case and cause the brushes to get stuck in their holders and lose contact. I can confrim this 1st hand as when my alts died a sharp rap on the case often got them going again and any time I pulled them apart their was lots of mud in the bottom of the case and in the brush holders.
His solution was to just re-index the case so the brushes were at the top and the vent at the bottom. This allowed the mud to run out the bottom and kept the brushes higher and drier. After I did this I didn't have any more alt problems.
The procedure is simple, remove alt, remove the 3 case screws and split the alt apart. Now reassemble the case so the brushes are near the top mount. When reassembling the case a wire needs to be insterted into the brush holders to hold the brushes in against the spring. Remeber to remove it when assembly is done."
Re: XJ Alternator?
« Reply #14 on: September 21, 2009, 07:38:36 PM »
I have also ground down the case mounting ears in some cases to make getting it back in easier.
