Author Topic: Tranny Down :(  (Read 2424 times)
Offline Aspirated
Re: Tranny Down :(
« Reply #15 on: September 23, 2009, 10:50:37 AM »
Buy some tools and a book if you want to keep the prices down? 4x4 ing is expensive...
1998 XJ
2008 KK
Re: Tranny Down :(
« Reply #16 on: September 23, 2009, 10:43:46 PM »
find a used ax-5 buddy. time to learn how to wrench on your vehicle...... i'm no parts store, but the parts you are asking for (assuming you find a good used tranny) aren't 600$..............
hit up kijiji and look for a tranny.  and learn how to do this stuff (if you have a garage)  otherwise you will learn the hard way that 'wheeling is expensive' (it is anyway)
good luck man
Re: Tranny Down :(
« Reply #17 on: September 24, 2009, 06:05:39 PM »
my other problem is that my front hub bearings are "loose" and about to go and also my front u joint
this has been estimated at my shop for 1250 with labour and everything
and im pretty sure its the ax-5 i could be wrong its running off the 2.5l 4 cyl
hubs for 1250? buy the parts (just as tinkerer said) and get me a fancy air compressor from Canadian tire (200$)
bring it over to my place and i'll help you switch them out yourself. you can save 800$ AND learn how to swap out a unit bearing............ oh, bring beer too............. (and leave the air compressor :D )
