Author Topic: wont start  (Read 1361 times)
Offline Justink
  • '89 comanche 5'' lift, 33's
wont start
« on: October 09, 2009, 02:44:16 PM »
I have a '91 cherokee with a 4.0 litre I6.  Drivin around today and she just stalled and wouldnt start again.  Lots of gas,  changed out the coil.  Just put 2 12 inch subs in and then i started havin the problems.  could the subs have screwed somethin electronic up.  if so what.
  Justin
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Offline apex
Re: wont start
« Reply #1 on: October 09, 2009, 11:04:40 PM »
Does your amp shut off when the key is out of the ingition?
Got a fuse in line?
Is you amp hot to the touch. Do you run ridiculous volumes?
double check all grounding and positive leads especially around firewalls.
Check the remote on off wiring on the amp.
Try upgrading your battery, alternator, and add a 1/2 farad capacitor.
Or take the subs out.
Offline Justink
Re: wont start
« Reply #2 on: October 10, 2009, 11:04:59 AM »
Did you screw through some wiring?  That was all too common during installs where I used to work...
Didn't screw or through nothing.  Started her up fine  today so the problems only when the motor warms up.  o2 sensor possibly?
Offline esi
Re: wont start
« Reply #3 on: October 10, 2009, 02:34:20 PM »
O2 sensor should just make it run crappy. Check CPS.
Formerly of Boots & Boost Inc
Offline Justink
Re: wont start
« Reply #4 on: October 10, 2009, 06:48:21 PM »
thinkin its distributor cap got power up to but not after distributor pulled it off its in pretty rough shape gonnja try changin that
