Author Topic: where r drain holes in lower yj frame rails ?  (Read 2036 times)
Offline hamrtime
« on: October 13, 2009, 12:05:16 PM »
where are the drain holes located ? ,  in the past I've stuck the hose in upper frame holes in wheelwell area
and pretty sure it ran out along the bottom of frame rail under driver somewhere ... seems their plugged
and I cant find them ...
thanks in advance
'89 yj - bought new - almost got my moneys worth
'97 xj - family cruiser now
Offline mike s
  • Good times!
Re: where r drain holes in lower yj frame rails ?
« Reply #1 on: October 14, 2009, 12:58:14 PM »
There supposed to be holes in bottom side of frame by rear shackles, where they also tend to rust out. Add some new holes on bottom of frame at all low points.
oldEnuff2NObetter
but still can't help myself
Offline hamrtime
« Reply #2 on: October 14, 2009, 09:59:41 PM »
been looking high/low and not a picture of where these might have been could I find
I know mine use to drain, they must have been smaller 1/4 or less hole(s) on each side
lots of frame rot pictures out there especially at the rear ... ouch
anyone got a picture of frame drain holes ?
Offline Gearhead
« Reply #3 on: October 15, 2009, 08:33:05 AM »
Yj's don't have drain holes , nothing a drill wouldn't fix.
I drilled a pair of drains in both frame rails , 3/8"   I believe  , if they become obstructed with mud ,  I poke a screwdriver through while the garden hose is  is turned on , when I'm   flushing the mud out.
Offline hamrtime
« Reply #4 on: October 18, 2009, 07:14:27 PM »
thanks - drilled 'em this aft ( 4x  5/16th ) - will run the hose thru later this week
