Author Topic: when to grease  (Read 1042 times)
Offline parabs
when to grease
« on: October 13, 2009, 06:16:33 PM »
Hey all,
when I changed out my canyons for the moabs, I noticed a few grease nipples that obviously need attention every now and again...the question is how often, and what kind of grease is good for canadian winters/summers?  Also, are these sealed units, or should I just pump away??  I would really hate to pop a seal if they are sealed units.
thx in advance.
2000 TJ Sahara - Sold
Offline esi
Re: when to grease
« Reply #1 on: October 13, 2009, 10:34:21 PM »
If there is a grease nipple, they aren't seal units, and if they haven't been hit for a while, pump until clean grease come out. Just to make sur all the crap comes out.
Formerly of Boots & Boost Inc
Offline Ostego
  • Full Size Jeep
Re: when to grease
« Reply #2 on: October 14, 2009, 09:28:42 AM »
I grease before and after wheeling.
If theres no wheeling just street driving, I do it every time I change the oil.
Re: when to grease
« Reply #3 on: October 14, 2009, 10:41:43 AM »
I would strongly recommend this grease, http://www.powerupmcs.com/thixogrease2info.html.  The only place that I have found that sells it is Bowness Auto and it is about $12 a tube.  I have been using this stuff for years and it works great.
Re: when to grease
« Reply #4 on: October 14, 2009, 10:50:31 AM »
grease em anytime you go through water. i grease mine every time i'm in the garage. everything with a nipple. so balljoints/ujoints/TREs shackles.
i use the canadian tire stuff cause i i got through a tube a month. (shackles hold lots of grease) although i'm sure my frame end bushings are gone.
in short. everytime you climb under there it can't hurt
