Author Topic: Eaton E Lockers  (Read 2969 times)
Offline starcreekyj
Eaton E Lockers
« on: October 19, 2009, 09:38:05 PM »
Has anyone had experience with Eaton E Lockers, most of the reviews I have read seem to be positive.
Lethbridge Coulee Kruzer
93 YJ With Mods
Re: Eaton E Lockers
« Reply #1 on: October 19, 2009, 09:40:42 PM »
We did a super 30 and super 35 in muffintops rig a few months back. They seem to be standing up well to his beadlocked 35's.
My buddy has one in his d60. He is on the second version. First one didnt fair so well, but eaton has completely re vamped them since. So far so good on his second one.
Offline yyc_tbird_sc
Re: Eaton E Lockers
« Reply #2 on: October 19, 2009, 11:21:27 PM »
I just picked one up for a HP D44 project I'm working on...everything I've heard so far has been good and the price couldn't have been beaten either!
Offline sn4cktime
Re: Eaton E Lockers
« Reply #3 on: October 20, 2009, 06:00:07 AM »
Version they initially had in the JK's seemed to fail due to water getting into something.  They did a recall after about 4 months and haven't heard anybody complaining about that issue since.  Kinda wish I had them in my rig now....  Grrrrrr....   And I don't think my computer has the capability to wire them up like stock, so I'd have to wire them through my sPod.  Only bonus to that is I could use them in 4H, and 2WD.
After how many ARB's I've seen fail due to the compressor dying, or frozen air line, or it just not engaging for who knows what reason then mysteriously working later, I'd be inclined to go electrical. Or possibly manual like a cable OX (<---$$$ warning on that though).
Offline GiS
Re: Eaton E Lockers
« Reply #4 on: October 20, 2009, 07:12:12 AM »
If you can search and find the recent thread we talked about the Eaton's, I gave some pretty decent technical data, and for you guys running the 8.8's or D44's they actually sell replacement parts but giving the change in design I doubt you will need them,
I accidentally turned my locker on last weekend at 96 km/h....Still works! :)
Offline muffintop
  • You spilled my macchiato!
Re: Eaton E Lockers
« Reply #5 on: October 20, 2009, 05:24:09 PM »
Got one in the front and one in the back. Have done everything from flat, narrow & winding trails --> mud --> water --> really steep & scary runs with stock I-6, 5 spd & transfer case... and I am super happy. I think I have wheeled it hard enough that if it was going to fail... it would have done so by now (touch wood).
This one may be obvious... but if you don't like wiring... you might not like installing Elockers. I spent alot of time and got alot of rib rash wiring up my TJ... but it was worth it.
The other thing to note/research is the Elocker design is different from large diffs (D60) to small diffs (D30) due to size constraints (thats what I read anyway). I would try and narrow down your search to someone running the same diff and then drill down to the specific design/re-design version (if applicable).
« Last Edit: October 20, 2009, 06:58:43 PM by muffintop »
2014 Jeep SRT
Offline starcreekyj
Re: Eaton E Lockers
« Reply #6 on: October 20, 2009, 08:01:30 PM »
Thanks Great info from all.
I have been sitting on the fence for a month or 2 trying to decide on a Detroit rear (8.8) and True Trac front (D30) or go with a selectable front and rear. For some reason I keep coming back and looking at the Elocker.
93 YJ With Mods
Offline stroker sahara
Re: Eaton E Lockers
« Reply #7 on: October 20, 2009, 09:36:57 PM »
I see Yukon is also making lockers now. Wonder how they are. I know they are a new product and all, so one may have to wait and see what the reviews are like.
Offline sn4cktime
Re: Eaton E Lockers
« Reply #8 on: October 21, 2009, 05:28:47 AM »
Selectable!!!
Wow, how did that feel at the time?  Did it actually engage at that speed or just grind like crazy?
Re: Eaton E Lockers
« Reply #9 on: October 21, 2009, 08:45:40 AM »
Selectable!!!
If he was going straight it should of had now affect because the spider gears don't turn
Offline muffintop
Re: Eaton E Lockers
« Reply #10 on: October 21, 2009, 09:51:44 AM »
Oh ya... I forgot to mention that when I first wired my TJ... I had my switches down by my gearshift. Then I almost mashed/acivated the switches while driving at higher speeds. That freaked me out so I bought a Daystar 2 rocker switch panel that replaces one of your vent assemblies (above the stereo in a TJ). Makes for a nice clean install and keeps the switches higher up and out of the way. Much lower probability of being accidentally activated.
« Last Edit: October 21, 2009, 09:53:23 AM by muffintop »
2014 Jeep SRT
Re: Eaton E Lockers
« Reply #11 on: October 22, 2009, 05:47:45 PM »
I have one in the front(D44) of my ZJ. Been in about 9 months now. Works fine, push button axle locks. No problems but then I haven't put a lot of miles on yet or really beat on it.
Ask Jessen over on 4wheeler.ca. He has one in the front of his XJ with a D44 and has beat on it quite a bit, he competes with it in the tough truck contests.
Offline dac
Re: Eaton E Lockers
« Reply #12 on: October 22, 2009, 06:03:27 PM »
Any one hear anything about there being no warranty with tires bigger than stock?  I had asked about one and was told there was a note that there was no warranty with larger than stock tires.
Re: Eaton E Lockers
« Reply #13 on: October 23, 2009, 10:20:50 PM »
Is there actually a warrenty on any lockers?
I've never expected there to be one.
Re: Eaton E Lockers
« Reply #14 on: October 23, 2009, 10:24:53 PM »
we returned an EZ locker to modern once. it was barely engaging. they gave us a brand new one.......   not sure if that was a manufactureres warranty or modern......... but they honoured it
