Author Topic: YJ door glass replacement  (Read 967 times)
Offline Eagle Jeeper
« on: October 24, 2009, 11:57:55 PM »
Could someone give me some tips on how to remove the glass from a YJ drivers door and install it again
Re: YJ door glass replacement
« Reply #1 on: October 26, 2009, 10:29:16 AM »
help :o
Offline BBD
« Reply #2 on: October 26, 2009, 01:37:09 PM »
remove window crank. there is a retainer clip behind it. remove door panel. install window crank without retainer. adjust until you can see how the window is attached to the manual regulator.  detach window from regulator. lower regulator to bottom. lower glass by hand to near bottom. tilt glass toward front of jeep. slowly lift glass out.
« Reply #3 on: October 26, 2009, 06:02:57 PM »
Thanks I'll get at it tonight or tomorrow
« Reply #4 on: December 01, 2009, 08:09:36 PM »
There was a few more steps than that ,  see Chiltons.  I never thought to look there in the first place.
