Author Topic: Superior axle seals yj two piece  (Read 1209 times)
Offline mike s
  • Good times!
« on: October 26, 2009, 11:44:50 PM »
Looking to replace plastic disc axle seals on yj with something far better. Anyone have the outer end of the right hand axle w/vacuum disconnect I could borrow and measure up? Thinking of two-piecing RH superior axle
tube seal housing and pinning halves together, once in axle tube, nowhere for
parts to go.
oldEnuff2NObetter
but still can't help myself
Offline cuzican
Re: Superior axle seals yj two piece
« Reply #1 on: October 27, 2009, 06:33:53 PM »
Wouldn't it just be easier/cheaper to get a one piece inner shaft from Pick n Pull. to replace the two piece shaft.
« Reply #2 on: October 27, 2009, 08:06:42 PM »
http://www.jeepforum.com/forum/f12/yj-front-solid-front-axles-868376/
i'm doing this mod buddy........ sooner than later. maybe christmas.  waiting for one piece chromoly's
Offline mike s
  • Good times!
« Reply #3 on: October 29, 2009, 11:24:43 PM »
My first thought was going to the one piece axle but hesitated spending more money on stock little diff. Tired of the stupid little plastic disc that is supposed to keep the muck awar from axle seals. Didn't want to tear mine apart just to measure
up axle but think I'll have time soon.
oldEnuff2NObetter
« Reply #4 on: October 30, 2009, 08:31:22 AM »
hey, if you want i've got a broken stub mike. the axle/seal etc, is all in tact, but the ujoint ears are broken off........... if you're measuring stuff it could work?
Offline mike s
  • Good times!
« Reply #5 on: November 01, 2009, 12:42:59 AM »
Is that the piece from u-joint in to the vacuum disconnect spline? I'd like to borrow it if you have it handy.
oldEnuff2NObetter
« Reply #6 on: November 01, 2009, 12:51:35 AM »
yuppers. like i said, its broken, but youcan use it for whatever you need for mockups!
Offline mike s
  • Good times!
« Reply #7 on: November 01, 2009, 11:13:06 PM »
Can I borrow it?
oldEnuff2NObetter
« Reply #8 on: November 02, 2009, 09:24:23 AM »
yup yup.
gimme a shout
403 993 8378
