Author Topic: AC Compressor pulley bearing  (Read 1681 times)
Offline fug
  • Airdrie Pick n Pull
« on: October 28, 2009, 08:38:15 AM »
Anyone ever replaced the AC pulley bearing?  The one on my 99 XJ is gone.  I've pulled the clutch off and determined it is indeed the pulley bearing as the compressor itself spins freely but the bearing is totally messed up.
I'm thinking I could press the bearing out and then put a new in.  Anyone know a good place to get this bearing?  I've heard they can be pricey.
Failing that... anyone know where I can get the whole pulley/clutch assembly (or even a whole compressor I can pull parts off of) for the AC on a 99 Cherokee?  I got one off a member here but it's a completely different setup.  My ccompressor has a keyed shaft and the clutch has exposed "rivets' like this:
Fug
TJ Rubicon
Re: AC Compressor pulley bearing
« Reply #1 on: October 28, 2009, 10:55:09 PM »
stampede auto wrecker on 52 ave formerly AAA junkyard before the fire has an 97 , 98. and a 99 xj in there yard .
They are also a self serve yard  :)   they have what you are looking for.
Offline fug
« Reply #2 on: October 28, 2009, 11:05:41 PM »
Thanks... might have to check that out.  I can't find anyone who lists just the clutch/pulley assembly and I've pulled parts off 3 different XJ's (an 88, a 96 and another 99).. and none are the same.
Fug
TJ Rubicon
Offline esi
« Reply #3 on: October 29, 2009, 09:58:43 PM »
If you're looking for just a bearing, try BC Bearing, or Kinecor.
Formerly of Boots & Boost Inc
« Reply #4 on: October 29, 2009, 10:38:18 PM »
Looked in the garage....
Looks the same.
Yours, if you want.
Offline fug
« Reply #5 on: October 29, 2009, 10:50:18 PM »
Awesome!!! Thats exactly it... the numbers on the sticker match exactly!  I'll give you a shout tomorrow and try to setup a time to grab it from you.  You working in town these days?
Fug
TJ Rubicon
